<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core S3 SD&#x2F;TF Card Issues]]></title><description><![CDATA[<p dir="auto">Hi Guys,</p>
<p dir="auto">I have a core S3 that I am trying to program via the Arduino IDE as UiFlow 2 is missing a lot of the capabilites for the S3.</p>
<p dir="auto">I have also tried this with a standard ESp32 S3 board and get the same issue but could do with some guidance.</p>
<p dir="auto">My Code:</p>
<pre><code>    // Include required libraries
    #include "M5CoreS3.h"
    #include "Arduino.h"
    #include "Audio.h"
    #include "SD.h"
    #include "FS.h"
    // microSD Card Reader connections
    #define SD_CS         15
    #define SPI_MOSI      37
    #define SPI_MISO      35
    #define SPI_SCK       36
    // I2S Connections
    #define I2S_DOUT      39
    #define I2S_BCLK      40
    #define I2S_LRC       41
    // Create Audio object
    Audio audio;
        M5.begin();
        // Set microSD Card CS as OUTPUT and set HIGH
        pinMode(SD_CS, OUTPUT);
        digitalWrite(SD_CS, HIGH);
        // Initialize SPI bus for microSD Card
        SPI.begin(SPI_SCK, SPI_MISO, SPI_MOSI);
        USBSerial.print("MOSI: ");
        USBSerial.println(MOSI);
        USBSerial.print("MISO: ");
        USBSerial.println(MISO);
        USBSerial.print("SCK: ");
        USBSerial.println(SCK);
        USBSerial.print("SS: ");
        USBSerial.println(SS);
        SPIClass SPI1(HSPI);
        // Start microSD Card
        if(!SD.begin(SD_CS, SPI1))
          USBSerial.println("Error accessing microSD card!");
          while(true);
        // Setup I2S
        audio.setPinout(I2S_BCLK, I2S_LRC, I2S_DOUT);
        USBSerial.println("Pinout Set!");
        // Set Volume
        audio.setVolume(5);
        USBSerial.println("Volume Set Set!");
        // Open music file
        audio.connecttoFS(SD,"/demo.mp3");
        USBSerial.println("File Open!");
    void loop()
        audio.loop();
<p dir="auto">Basically, I keep getting the message "Error accessing microSD card!" on the terminal.  Pretty sure I have the pins right?  And the card is formatted to FAT32.</p>
<p dir="auto">For some reason, I just cannot get it to read</p>
<p dir="auto">Any Ideas?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://community.m5stack.com/topic/5415/core-s3-sd-tf-card-issues</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 00:10:03 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5415.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 24 Jun 2023 23:48:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Core S3 SD&#x2F;TF Card Issues on Sun, 12 Jan 2025 13:25:03 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/lordinchcape" aria-label="Profile: LordInchcape">@<bdi>LordInchcape</bdi></a></p>
<p dir="auto">not that I know of. That said, have you tried to see what Micropython code UIFlow2 produces?</p>
]]></description><link>https://community.m5stack.com/post/27865</link><guid isPermaLink="true">https://community.m5stack.com/post/27865</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 12 Jan 2025 13:25:03 GMT</pubDate></item><item><title><![CDATA[Reply to Core S3 SD&#x2F;TF Card Issues on Sun, 12 Jan 2025 12:38:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> Hello. Does a micropython example of this exist? Thanks.</p>
]]></description><link>https://community.m5stack.com/post/27863</link><guid isPermaLink="true">https://community.m5stack.com/post/27863</guid><dc:creator><![CDATA[LordInchcape]]></dc:creator><pubDate>Sun, 12 Jan 2025 12:38:18 GMT</pubDate></item><item><title><![CDATA[Reply to Core S3 SD&#x2F;TF Card Issues on Mon, 26 Jun 2023 07:16:34 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/djh82uk" aria-label="Profile: djh82uk">@<bdi>djh82uk</bdi></a></p>
<p dir="auto">I found a way to use the SD card w/o compromising the TFT. You can find it <a href="https://github.com/felmue/MyM5StackExamples/blob/main/M5CoreS3/SDCardAndLCD/SDCardAndLCD.ino" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
]]></description><link>https://community.m5stack.com/post/21333</link><guid isPermaLink="true">https://community.m5stack.com/post/21333</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 26 Jun 2023 07:16:34 GMT</pubDate></item><item><title><![CDATA[Reply to Core S3 SD&#x2F;TF Card Issues on Sun, 25 Jun 2023 10:30:43 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/djh82uk" aria-label="Profile: djh82uk">@<bdi>djh82uk</bdi></a></p>
<p dir="auto">firstly SD_CS is GPIO 4 - see pin map <a href="http://docs.m5stack.com/en/core/CoreS3" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
<p dir="auto">Secondly it looks like the TFT (which also uses SPI) uses MISO as DC. From an ESP32 perspective MISO is an input but DC needs to be an output. So the TFT driver configures the MISO GPIO to an output. This conflicts with the SD card, which is on the same SPI bus and requires MISO to be an input. Not sure how to resolve that so that TFT and SD card can coexist.</p>
<p dir="auto">Thirdly the M5CoreS3 library sets the voltage for the SD card incorrectly to 1.3 V instead of 3.3 V. I posted a <a href="https://github.com/m5stack/M5CoreS3/pull/35" target="_blank" rel="noopener noreferrer nofollow ugc">PR</a> for that.</p>
<p dir="auto">A simple SD card example which works for me (but it disables the TFT) is <a href="https://github.com/felmue/MyM5StackExamples/blob/main/M5CoreS3/SDCard/SDCard.ino" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
]]></description><link>https://community.m5stack.com/post/21313</link><guid isPermaLink="true">https://community.m5stack.com/post/21313</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 25 Jun 2023 10:30:43 GMT</pubDate></item></channel></rss>
