<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ExtPort for Core2, two DS18B20 and one Kmeter, pin problem]]></title><description><![CDATA[<p dir="auto">I have Core2 with Extport for Core2. I soldered A port to open connector as it's easier to use with mounting frame than using A connector in Core2. This A-port has Kmeter connected and works well. I have stonatm DS18B20 custom component (<a href="https://github.com/stonatm/UiFlow-custom-blocks/tree/master/ds18b20" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/stonatm/UiFlow-custom-blocks/tree/master/ds18b20</a>), that requires every DS to have separate pin. I have one DS18B20 connected to Port C, using pin 13 (default).</p>
<p dir="auto">Now, the problem is, which port to use for second DS18B20? A-port is used for Kmeter. ESP32 reserves pin 34-39 for "input only" and if I try to use port B, D or E, Core2 gives error on screen. Is it possible to set dip switches in a such manner, that those previously mentioned ports can be used? Or use B port and rewire DS18B20 connector by swapping pins 1 and 2 in Grove-connector, as then pins 26 and 36 will are swapped in port B. Will it work?</p>
<p dir="auto">If there's working DS18B20 custom component that allow multiple sensors in single line, can someone link to it, it will work in this use case too.</p>
<p dir="auto">Thanks in advance!</p>
]]></description><link>https://community.m5stack.com/topic/5490/extport-for-core2-two-ds18b20-and-one-kmeter-pin-problem</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 11:29:06 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5490.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 15 Jul 2023 18:37:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ExtPort for Core2, two DS18B20 and one Kmeter, pin problem on Sun, 16 Jul 2023 14:04:25 GMT]]></title><description><![CDATA[<p dir="auto">I did rewiring for DS-sensor grove-connector, works perfectly and was easiest.</p>
]]></description><link>https://community.m5stack.com/post/21592</link><guid isPermaLink="true">https://community.m5stack.com/post/21592</guid><dc:creator><![CDATA[honkkis]]></dc:creator><pubDate>Sun, 16 Jul 2023 14:04:25 GMT</pubDate></item></channel></rss>
