<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5paper no longer works with Arduino from new installs]]></title><description><![CDATA[<p dir="auto">Hi</p>
<p dir="auto">Why is it so complicated to set up the development environement for the m5paper?</p>
<p dir="auto">The only reliable environment is the UIflow, which works consistently. but seems a bit limited.</p>
<p dir="auto">The other other environments I've tried are Arduino - painfully slow (even with output disabled), and after compiling it doesnt reset the m5paper to run the code.   I assume a later library or something has broken it?</p>
<p dir="auto">ditto for VScode and Moddable</p>
<p dir="auto">The "Hard resetting via RTS" doesn't reset it.<br />
Python 3.11 seems to have broken it</p>
<p dir="auto">Maybe I'm being a bit impatient, but I <em>dont</em> want to have weeks configuring/fixing broken development environment(s), I want to learn how code for the m5paper.</p>
<p dir="auto">=&gt; Which is stable and doesn't take ages to compile programs, and is compatible with m5paper?</p>
<p dir="auto">Maybe my expectations were a bit high, but it does seem to be new user hostile!<br />
Maybe I should stick with the UIflow.</p>
<p dir="auto">Ta</p>
]]></description><link>https://community.m5stack.com/topic/5492/m5paper-no-longer-works-with-arduino-from-new-installs</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 05:06:46 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5492.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 15 Jul 2023 14:01:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5paper no longer works with Arduino from new installs on Fri, 21 Jul 2023 15:57:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> thanx for your afford, but that makes no sense. functionality will be same and just needs to be adjusted to the display. we all know that e-ink is different than lcd, so its no help pointing that out.</p>
]]></description><link>https://community.m5stack.com/post/21638</link><guid isPermaLink="true">https://community.m5stack.com/post/21638</guid><dc:creator><![CDATA[EBKsuper]]></dc:creator><pubDate>Fri, 21 Jul 2023 15:57:21 GMT</pubDate></item><item><title><![CDATA[Reply to M5paper no longer works with Arduino from new installs on Sun, 16 Jul 2023 18:46:37 GMT]]></title><description><![CDATA[<p dir="auto">I tried to teach a YouTuber Arduino core the AtomS3 and I hate Arduino it is a monster pain to use and so many libraries have to be installed just to do anything.</p>
<p dir="auto">Also Ink/papers are complicated because they work fundamentally differently to tft/LCD OLED displays.</p>
]]></description><link>https://community.m5stack.com/post/21598</link><guid isPermaLink="true">https://community.m5stack.com/post/21598</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 16 Jul 2023 18:46:37 GMT</pubDate></item><item><title><![CDATA[Reply to M5paper no longer works with Arduino from new installs on Sun, 16 Jul 2023 16:59:17 GMT]]></title><description><![CDATA[<p dir="auto">I am with you.<br />
I try to get something usefull out my m5coreInk but there is no help/support/documentation out there at all.</p>
]]></description><link>https://community.m5stack.com/post/21593</link><guid isPermaLink="true">https://community.m5stack.com/post/21593</guid><dc:creator><![CDATA[EBKsuper]]></dc:creator><pubDate>Sun, 16 Jul 2023 16:59:17 GMT</pubDate></item></channel></rss>
