<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[SSL Socket errors]]></title><description><![CDATA[<p dir="auto">Greetings and thank-you for your time.</p>
<p dir="auto">I am trying to send camera images from my ESP32 (M5 Stack PoECAM) to my personal google drive.</p>
<p dir="auto">following this tutorial :<br />
<a href="https://hobby-it.com/m5timer_gdrive-2/" target="_blank" rel="noopener noreferrer nofollow ugc">https://hobby-it.com/m5timer_gdrive-2/</a></p>
<p dir="auto">I have setup SSLClient with the EthernetLarge library the jpgs arrive and but they are corrupted/incomplete. Any ideas why this might be happening, I have tried different chunk sizes no effect ?</p>
<p dir="auto">I don't believe its hardware as the example sketches all work as intended</p>
<p dir="auto">errors/warnings</p>
<pre><code>SSLClient)(SSL_WARN)(connected): Socket was dropped unexpectedly (this can be an alternative to closing the connection)
(SSLClient)(SSL_ERROR)(m_print_ssl_error): SSL_CLIENT_WRITE_FAIL
(SSLClient)(SSL_ERROR)(available): Cannot operate if the write error is not reset:
<p dir="auto">The project is on github (<a href="https://gitlab.com/ArchNemsys/esp32-poe-cam" target="_blank" rel="noopener noreferrer nofollow ugc">https://gitlab.com/ArchNemsys/esp32-poe-cam</a>) the code for the relevant function (sensitive data removed) is posted below apologies I was halfway through refactoring it to use char bufs rather than strings:</p>
<pre><code>#include &lt;SSLClient.h&gt;
#include "gdrive_trust.h"
#define WRITE_SIZE_MAX   1024 //
//#define API_PORT    443
//#define API_PATH_TOKEN   "/oauth2/v4/token"
const char* refreshServer = "oauth2.googleapis.com";
const char* refreshUri    = "/token";
const char* apiServer     = "www.googleapis.com";
const char* apiUri        = "/upload/drive/v3/files?uploadType=multipart";
char accessToken[2048];
// ethClient is declared elsewhere but works perfectly outside this funciton
SSLClient httpsClient(ethClient, gdriveTAs, 1, 25);
//  SSLClient::write, is buffered does not actually write to the network. you must call SSLClient::available or SSLClient::flush,
int waitingTime      = 10000; // Wait 10 seconds to google response.
// Send JPEG by Http POST
void postGoogleDriveByAPI() {
  Serial.println("Connect to " + String(apiServer));
  if (httpsClient.connect(apiServer, 443)) {
    Serial.println("Connection successful");
    // Get Time for save file name
    struct tm timeinfo;
    if(!getLocalTime(&amp;timeinfo)){
      Serial.println("Failed to obtain time 1");
      return;
    char saveFilename[64];
    char metadata[256];
    const char* startBoundry = "--foo_bar_baz\r\n"
                      "Content-Type:image/jpeg\r\n\r\n";
    const char* endBoundry = "\r\n--foo_bar_baz--";
    strftime (saveFilename,64,"ALERT_%A_%B_%d_%Y_%Hh%Mm%Ss.jpg",&amp;timeinfo);
    Serial.println(saveFilename);
    snprintf( metadata, 256, "--foo_bar_baz\r\n"
                      "Content-Type: application/json; charset=UTF-8\r\n\r\n"
                      "{\"name\":\"%s\",\"parents\":[\"%s\"]}\r\n\r\n" , saveFilename, PARENT_ID );
    unsigned long contentsLength = strlen(metadata) + strlen(startBoundry) + fb-&gt;len + strlen(endBoundry);
    snprintf(header,256, "POST %s HTTP/1.1\r\n"
                    "HOST: %s \r\n"
                    "Connection: close\r\n"
                    "content-type: multipart/related; boundary=foo_bar_baz\r\n"
                    "content-length: %u \r\n"
                    "authorization: Bearer %s \r\n\r\n", apiUri, apiServer, contentsLength, accessToken);
    String metadata = "--foo_bar_baz\r\n"
                      "{\"name\":\"" + String(saveFilename) + "\",\"parents\":[\"" + String(PARENT_ID) + "\"]}\r\n\r\n"; // parents:save folder
                      //"{\"name\":\"" + saveFilename + "\"}\r\n\r\n"; // parerents is Optional
    String startBoundry = "--foo_bar_baz\r\n"
    String endBoundry   = "\r\n--foo_bar_baz--";
    unsigned long contentsLength = metadata.length() + startBoundry.length() + fb-&gt;len + endBoundry.length();
    String header = "POST " + String(apiUri) + " HTTP/1.1\r\n" +
                    "HOST: " + String(apiServer) + "\r\n" +
                    "Connection: close\r\n" +
                    "content-type: multipart/related; boundary=foo_bar_baz\r\n" +
                    "content-length: " + String(contentsLength) + "\r\n" +
                    "authorization: Bearer " + accessToken + "\r\n\r\n";
    Serial.println("Send JPEG DATA by API");
    httpsClient.print(header);
    httpsClient.print(metadata);
    httpsClient.print(startBoundry);
    // JPEG data is separated into 1000 bytes and POST
    int chunk = 1000;
    unsigned long dataLength = fb-&gt;len;
    uint8_t*      bufAddr    = fb-&gt;buf;
    for(unsigned long i = 0; i &lt; dataLength ;i=i+chunk) {
      if ( (i + chunk) &lt; dataLength ) {
        httpsClient.write(( bufAddr + i ), chunk);
      } else if (dataLength%chunk != 0) {
        httpsClient.write(( bufAddr + i ), dataLength%chunk);
    httpsClient.print(endBoundry);
    Serial.println("Waiting for response.");
    long int StartTime=millis();
    while (!httpsClient.available()) {
      Serial.print(".");
      delay(100);
      if ((StartTime+waitingTime) &lt; millis()) {
        Serial.println();
        Serial.println("No response.");
        break;
  } else {
    Serial.println("Connected to " + String(refreshServer) + " failed.");
  httpsClient.stop();
]]></description><link>https://community.m5stack.com/topic/5494/ssl-socket-errors</link><generator>RSS for Node</generator><lastBuildDate>Mon, 04 May 2026 09:45:06 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5494.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 17 Jul 2023 06:09:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to SSL Socket errors on Mon, 17 Jul 2023 17:42:08 GMT]]></title><description><![CDATA[<p dir="auto">error found the Framebuffer fb was being freed before the SSLClient could finish writing hence the corrupted drive image.</p>
]]></description><link>https://community.m5stack.com/post/21607</link><guid isPermaLink="true">https://community.m5stack.com/post/21607</guid><dc:creator><![CDATA[nemsys]]></dc:creator><pubDate>Mon, 17 Jul 2023 17:42:08 GMT</pubDate></item></channel></rss>
