<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[DMX_Base output is unstable]]></title><description><![CDATA[<p dir="auto">When I use the DMX_Base with the Core2 v1.12.1 and UIFlow 1.0 Latest (web interface), the output is not stable. I am using a tried-and-true Goddard Design Lil'DMXter to read the DMX512 data from the DMX_Base. It is able to accept the signal and can intermittently pick up the correct values. Some channels work better than others. For example, channel 4 seems to update steadily while channels 1 through 3 will rarely have the correct value. I have tested this only with the 3-pin XLR board. I have tested the following switch configurations</p>
<li>S1 right, S2 right, S3 off</li>
<li>S1 right, S2, right, S3 on</li>
<li>S1 left, S2 left, S3 on</li>
<p dir="auto">I have not tried Arduino yet but the website says "no official M5Stack library for the DMX512 module" so I am not sure that it would be a good idea to use Arduino instead of UIFlow. I suspect a software issue with the RS485 timing. Is this a known issue?</p>
<p dir="auto">Thank you,<br />
Adam</p>
]]></description><link>https://community.m5stack.com/topic/5503/dmx_base-output-is-unstable</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 14:54:33 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5503.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 20 Jul 2023 20:35:09 GMT</pubDate><ttl>60</ttl></channel></rss>
