<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Not able to pair Core2 with my account]]></title><description><![CDATA[<p dir="auto">After downloading the new firmware UI Flow2 for my Core2 and the first burn, I was requested to pair the device with my account and there was an error. The burning was at the end successful as "private" without an account. Now I can not add this device to my account and as it is set to private (what I can not change) I can not use the device with an public key.</p>
<p dir="auto">Reburning or re download the firmware, erease and so on .. I did all things without success.</p>
]]></description><link>https://community.m5stack.com/topic/5509/not-able-to-pair-core2-with-my-account</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 14:09:58 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5509.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 22 Jul 2023 06:06:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Not able to pair Core2 with my account on Wed, 02 Aug 2023 12:45:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mchott" aria-label="Profile: mchott">@<bdi>mchott</bdi></a> the only thing right now .. after whatever .. it appears in the menu in UIflow 2 .. but I don´t have any idea what this caused</p>
]]></description><link>https://community.m5stack.com/post/21759</link><guid isPermaLink="true">https://community.m5stack.com/post/21759</guid><dc:creator><![CDATA[mchott]]></dc:creator><pubDate>Wed, 02 Aug 2023 12:45:17 GMT</pubDate></item><item><title><![CDATA[Reply to Not able to pair Core2 with my account on Wed, 02 Aug 2023 12:43:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rasbr" aria-label="Profile: rasbr">@<bdi>rasbr</bdi></a> no .. I tried many things and have no solution</p>
<p dir="auto">"you don’t need to switch to Micropython as UIFlow is built on Micropython" .. yes I know but it´s different of using the blockly UI or just write lines of code. Yes both is possible with UIflow but if I decide for more functionallity and using Micropython in UIflow there is no real way back. In my opinion this is a way between. Blockly UIflow &gt; Micropython UIflow &gt; Arduino IDE &gt; ...</p>
]]></description><link>https://community.m5stack.com/post/21758</link><guid isPermaLink="true">https://community.m5stack.com/post/21758</guid><dc:creator><![CDATA[mchott]]></dc:creator><pubDate>Wed, 02 Aug 2023 12:43:41 GMT</pubDate></item><item><title><![CDATA[Reply to Not able to pair Core2 with my account on Fri, 28 Jul 2023 20:36:12 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/mchott" aria-label="Profile: mchott">@<bdi>mchott</bdi></a><br />
I am stuck like you with private device without being able to connect to UiFlow2.</p>
<p dir="auto">Did you find a solution yet?</p>
]]></description><link>https://community.m5stack.com/post/21725</link><guid isPermaLink="true">https://community.m5stack.com/post/21725</guid><dc:creator><![CDATA[RASBR]]></dc:creator><pubDate>Fri, 28 Jul 2023 20:36:12 GMT</pubDate></item><item><title><![CDATA[Reply to Not able to pair Core2 with my account on Mon, 24 Jul 2023 15:24:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mchott" aria-label="Profile: mchott">@<bdi>mchott</bdi></a> you don’t need to switch to Micropython as UIFlow is built on Micropython. You can use an ide like Thonny to extend the UIFlow/Micropython program and using thonny, you can load the file off the core2 and keep developing.</p>
<p dir="auto">Switching to arduino does have some be if it’s but also has major headaches</p>
]]></description><link>https://community.m5stack.com/post/21676</link><guid isPermaLink="true">https://community.m5stack.com/post/21676</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 24 Jul 2023 15:24:09 GMT</pubDate></item><item><title><![CDATA[Reply to Not able to pair Core2 with my account on Sun, 23 Jul 2023 05:26:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sirspot" aria-label="Profile: sirspot">@<bdi>sirspot</bdi></a> Yes it´s possible to go back to the latest UiFlow 1</p>
<p dir="auto">I just wanted to test what is possible with UiFlow 2. This tiny project has it´s limitations with UiFlow 1 and before I switch to developing with Arduino or Micropython or whatever I just wanted to try UiFlow 2 because it´s now available.</p>
]]></description><link>https://community.m5stack.com/post/21653</link><guid isPermaLink="true">https://community.m5stack.com/post/21653</guid><dc:creator><![CDATA[mchott]]></dc:creator><pubDate>Sun, 23 Jul 2023 05:26:24 GMT</pubDate></item><item><title><![CDATA[Reply to Not able to pair Core2 with my account on Sun, 23 Jul 2023 03:05:20 GMT]]></title><description><![CDATA[<p dir="auto">I tried to get my core2 working with uiflow 2 but also could not make much progress. I went back to latest uiflow 1.0 with no problems.</p>
]]></description><link>https://community.m5stack.com/post/21652</link><guid isPermaLink="true">https://community.m5stack.com/post/21652</guid><dc:creator><![CDATA[sirspot]]></dc:creator><pubDate>Sun, 23 Jul 2023 03:05:20 GMT</pubDate></item></channel></rss>
