<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Consider making an SDR Base for M5Stack using Si4732 chip or similar]]></title><description><![CDATA[<p dir="auto">Please consider making an M5Stack base for the Si4732 chip or similar SDR chip. Much firmware has already been created for ESP32 and Si4732, see: <a href="http://harduino.ru/index.php/en/download" target="_blank" rel="noopener noreferrer nofollow ugc">http://harduino.ru/index.php/en/download</a> There are many, many clones of the ATS-25 radio so the firmware is easily obtainable. The ATS-25 radio can be found online everywhere, it has a color LCD display similar to M5Stack. It is also possible to use many SDR chips in a USB dongle form factor.</p>
<p dir="auto">Thanks,<br />
Akhanaton</p>
]]></description><link>https://community.m5stack.com/topic/5526/consider-making-an-sdr-base-for-m5stack-using-si4732-chip-or-similar</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 22:12:00 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5526.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 25 Jul 2023 22:39:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Consider making an SDR Base for M5Stack using Si4732 chip or similar on Sun, 21 Jul 2024 17:03:18 GMT]]></title><description><![CDATA[<p dir="auto">One in Grove I2C format so can be used with ATOM too, maybe with an extra onboard IC for decoding packet radio and 3.5mm plug for output, also included 3.5mm to Grove cable for doing stuff with signal on host</p>
]]></description><link>https://community.m5stack.com/post/25899</link><guid isPermaLink="true">https://community.m5stack.com/post/25899</guid><dc:creator><![CDATA[snesee]]></dc:creator><pubDate>Sun, 21 Jul 2024 17:03:18 GMT</pubDate></item></channel></rss>
