<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Twisted Pair Cable Specifications]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I recently ordered some of the twisted pair cables with ferrules (<a href="https://docs.m5stack.com/en/accessory/cable/24awg_cable" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/accessory/cable/24awg_cable</a>). They're sold as Shielded Twisted Pair, but the documentation doesn't specify which colours are paired together.</p>
<p dir="auto">In addition, the colours specified in the documentation include <code>white</code>, but I received cable without a <code>white</code> wire. Instead there is a <code>yellow</code> wire.</p>
<p dir="auto">If anyone could help with details about which colours compose the two pairs it would be appreciated.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://community.m5stack.com/topic/5533/twisted-pair-cable-specifications</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 11:06:12 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5533.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 31 Jul 2023 19:29:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Twisted Pair Cable Specifications on Thu, 03 Aug 2023 11:59:45 GMT]]></title><description><![CDATA[<p dir="auto">The support team disassembled a cable and the pairs are:</p>
<li>Red and black</li>
<li>green and yellow</li>
]]></description><link>https://community.m5stack.com/post/21775</link><guid isPermaLink="true">https://community.m5stack.com/post/21775</guid><dc:creator><![CDATA[daveismith]]></dc:creator><pubDate>Thu, 03 Aug 2023 11:59:45 GMT</pubDate></item><item><title><![CDATA[Reply to Twisted Pair Cable Specifications on Thu, 03 Aug 2023 06:08:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/blackfigcurrant" aria-label="Profile: blackfigcurrant">@<bdi>blackfigcurrant</bdi></a> said in <a href="/post/21765">Twisted Pair Cable Specifications</a>:</p>
<p dir="auto">you're all set with those colors! They should do the job just fine.</p>
<p dir="auto">This response made me actually LOL.</p>
]]></description><link>https://community.m5stack.com/post/21770</link><guid isPermaLink="true">https://community.m5stack.com/post/21770</guid><dc:creator><![CDATA[mtylerjr]]></dc:creator><pubDate>Thu, 03 Aug 2023 06:08:17 GMT</pubDate></item><item><title><![CDATA[Reply to Twisted Pair Cable Specifications on Thu, 03 Aug 2023 04:37:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/blackfigcurrant" aria-label="Profile: blackfigcurrant">@<bdi>blackfigcurrant</bdi></a> said in <a href="/post/21765">Twisted Pair Cable Specifications</a>:</p>
<p dir="auto">This didn’t answer the question. I need to know the combinations of colours inside the cable which are twisted together (eg, black and red are pair one while green and yellow are pair two vs black and yellow are pair one while red and green and pair two)</p>
<p dir="auto">This is important for signal integrity for differential protocols such as RS485 or RS422. The whole point of using a twisted pair in these cases is to put the negative and positive components of a signal over the pair so that any interference picked up will impact both the negative and positive signals in the same way and leave you with the same differential.</p>
]]></description><link>https://community.m5stack.com/post/21768</link><guid isPermaLink="true">https://community.m5stack.com/post/21768</guid><dc:creator><![CDATA[daveismith]]></dc:creator><pubDate>Thu, 03 Aug 2023 04:37:55 GMT</pubDate></item><item><title><![CDATA[Reply to Twisted Pair Cable Specifications on Wed, 02 Aug 2023 16:46:50 GMT]]></title><description><![CDATA[<p dir="auto">you're all set with those colors! They should do the job just fine.</p>
]]></description><link>https://community.m5stack.com/post/21765</link><guid isPermaLink="true">https://community.m5stack.com/post/21765</guid><dc:creator><![CDATA[blackfigcurrant]]></dc:creator><pubDate>Wed, 02 Aug 2023 16:46:50 GMT</pubDate></item></channel></rss>
