<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can&#x27;t connect servers other than http:&#x2F;&#x2F;api.m5stack.com&#x2F;v1 with UIFlow_Lite firmware versions after v.1.9.7]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">The following code works fine with the UIFlow_Lite firmware versions between v1.7.5 and v1.9.6.</p>
<p dir="auto"><a href="https://gist.github.com/kotobuki/aab0a8b0e65e501c8a354198bdc4d969" target="_blank" rel="noopener noreferrer nofollow ugc">https://gist.github.com/kotobuki/aab0a8b0e65e501c8a354198bdc4d969</a></p>
<p dir="auto"><img src="https://user-images.githubusercontent.com/10932/258554270-da6a7e2f-a071-45ab-b692-72341a049d3d.png" alt="uiflow_block_1691196143657" class=" img-fluid img-markdown" /></p>
<p dir="auto">However, the HTTP request fails with versions after v1.9.7, including v.12.2. If I change the URL to <a href="http://api.m5stack.com/v1" target="_blank" rel="noopener noreferrer nofollow ugc">http://api.m5stack.com/v1</a>, it also works fine with those versions. It seems that firmware versions after v1.9.7 only accept the URL for GET HTTP requests.</p>
<p dir="auto">I'm sorry if this is a false alarm.</p>
<p dir="auto">Best,<br />
Shigeru</p>
]]></description><link>https://community.m5stack.com/topic/5545/can-t-connect-servers-other-than-http-api-m5stack-com-v1-with-uiflow_lite-firmware-versions-after-v-1-9-7</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 10:02:29 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5545.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 05 Aug 2023 00:45:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can&#x27;t connect servers other than http:&#x2F;&#x2F;api.m5stack.com&#x2F;v1 with UIFlow_Lite firmware versions after v.1.9.7 on Fri, 18 Aug 2023 07:09:31 GMT]]></title><description><![CDATA[<p dir="auto">Update: I confirmed that I can reproduce this issue with the latest version (i.e., v1.12.3). I also tried specifying the SSID and PASSWORD using a Network block but got no luck. Can anybody else reproduce this issue?</p>
]]></description><link>https://community.m5stack.com/post/21990</link><guid isPermaLink="true">https://community.m5stack.com/post/21990</guid><dc:creator><![CDATA[kotobuki]]></dc:creator><pubDate>Fri, 18 Aug 2023 07:09:31 GMT</pubDate></item></channel></rss>
