<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[function returning accel values of MPU6886 is buggy x and Z values are alwas identical]]></title><description><![CDATA[<p dir="auto">Hi,<br />
in my previous post <a href="https://community.m5stack.com/topic/5561/imu-getaccel-returns-gyro-values">https://community.m5stack.com/topic/5561/imu-getaccel-returns-gyro-values</a> I pointed out that UIFLOW2 repectively the phython code generated by blockly returns in case of my Atom S3 the wrong values, namely:</p>
<p dir="auto">Imu.getGyro() returns accel values<br />
and<br />
Imu.getAccel() returns gyro values.</p>
<p dir="auto">I noticed a further bug:<br />
the accel values returned by Imu.getGyro() for x and z are always identical. If I tap on the device or move it around the x and the z values are always identical.</p>
<p dir="auto">I assume that the library has a bug. However I can not rule out that the the mpu6886 is wrongly wired to the esp32.</p>
<p dir="auto">Could you please check whether the library is the cause for this strange behaviour.</p>
Nestor</p>
]]></description><link>https://community.m5stack.com/topic/5563/function-returning-accel-values-of-mpu6886-is-buggy-x-and-z-values-are-alwas-identical</link><generator>RSS for Node</generator><lastBuildDate>Tue, 05 May 2026 18:32:46 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5563.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 10 Aug 2023 11:49:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to function returning accel values of MPU6886 is buggy x and Z values are alwas identical on Fri, 11 Aug 2023 02:13:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nestor89" aria-label="Profile: Nestor89">@<bdi>Nestor89</bdi></a> Thanks, you're right, it's a bug.</p>
]]></description><link>https://community.m5stack.com/post/21863</link><guid isPermaLink="true">https://community.m5stack.com/post/21863</guid><dc:creator><![CDATA[lbuque]]></dc:creator><pubDate>Fri, 11 Aug 2023 02:13:05 GMT</pubDate></item></channel></rss>
