<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Control Stepper Motor with Core2 and GRBL 13.2]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I'm using the Core2 controller and the GRBL 13.2 module. I want to drive two stepper motors continually at a slow speed. The motors are attached to rollers, so they should be continuously rolling.</p>
<p dir="auto">The motor I purchased is a Nema 17 bipolar from here: <a href="https://www.ebay.com.au/itm/175580114720" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.ebay.com.au/itm/175580114720</a></p>
<p dir="auto">I have the motor turning using the example Arduino code, but the torque is very low; we can twist the axel easily.<br />
What could be causing the toque to be so low? Have I specced the motor incorrectly, or do I need a different driver?<br />
Thanks</p>
]]></description><link>https://community.m5stack.com/topic/5573/control-stepper-motor-with-core2-and-grbl-13-2</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 22:44:40 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5573.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 14 Aug 2023 07:03:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Control Stepper Motor with Core2 and GRBL 13.2 on Tue, 15 Aug 2023 05:50:39 GMT]]></title><description><![CDATA[<p dir="auto">Could be alsorts like incorrect supply voltage, incorrect setting on the module or issues with the code.</p>
]]></description><link>https://community.m5stack.com/post/21932</link><guid isPermaLink="true">https://community.m5stack.com/post/21932</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 15 Aug 2023 05:50:39 GMT</pubDate></item></channel></rss>
