<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5StackCore2 Can Port A be used as Serial port ?]]></title><description><![CDATA[<p dir="auto">Hi All,</p>
<p dir="auto">I am new to m5stack. I just wanted to understand if PORT A on the device can be used as a software serial? If so what is the PORT numbers i need to use? I tried G32 and G33 with no luck.</p>
]]></description><link>https://community.m5stack.com/topic/5577/m5stackcore2-can-port-a-be-used-as-serial-port</link><generator>RSS for Node</generator><lastBuildDate>Mon, 04 May 2026 09:45:07 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5577.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 15 Aug 2023 01:44:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5StackCore2 Can Port A be used as Serial port ? on Wed, 16 Aug 2023 15:25:52 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/talktosanjay3" aria-label="Profile: talktosanjay3">@<bdi>talktosanjay3</bdi></a></p>
<p dir="auto">by default port A is for external I2C; however M5Core2 uses two dedicated GPIOs (32/33) for port A so it should be possible to use it for anything as by default external I2C is not being initialized.</p>
<p dir="auto">Can you share the code you tried?</p>
]]></description><link>https://community.m5stack.com/post/21959</link><guid isPermaLink="true">https://community.m5stack.com/post/21959</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 16 Aug 2023 15:25:52 GMT</pubDate></item></channel></rss>
