<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack Fire dead and getting hot after testing Steppermodule and Servomodule together]]></title><description><![CDATA[<p dir="auto">Good Morning,<br />
Yesterday I got a nice package from m5 with my awaited Stepper and Servo modules which I need both for a project.<br />
My first test was the Stepper-Module (with original power adapter)  on a Fire and the provided test sketch.<br />
It worked perfectly.<br />
My Second Test was adding the Servo module as well and i combined Stepper and Servo test sketch.<br />
It worked as well.</p>
<p dir="auto">After combining the two sketches ,stacking Stepper and Servo board and connecting power nothing happened.<br />
While disconnecting and disassembling again to check what could have gone wrong i burned my thumb on the really hot esp32 cover.<br />
So obviously something has gone terribly wrong.<br />
It seems that the fire is dead now and if i connect it to usb it gets hot again and does not do anything.</p>
<p dir="auto">Probably somebody from m5 can check this - i don't want anybody else to have the same issue with a killed M5 Fire</p>
<p dir="auto">Cheers Chris</p>
]]></description><link>https://community.m5stack.com/topic/561/m5stack-fire-dead-and-getting-hot-after-testing-steppermodule-and-servomodule-together</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 14:13:01 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/561.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 31 Jan 2019 06:44:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stack Fire dead and getting hot after testing Steppermodule and Servomodule together on Mon, 04 Feb 2019 06:15:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> yes I did use the cooling module as well.<br />
My thought was that there probably is some electrical interference when using the stepper and the servo module together. My solution in that case will be that i disconnect the mbus from the voltage regulator +wire completely to only power the steppers with the external power supply and do the rest with usb power to the m5Stack, so i am safe :D</p>
]]></description><link>https://community.m5stack.com/post/2846</link><guid isPermaLink="true">https://community.m5stack.com/post/2846</guid><dc:creator><![CDATA[MrTarantl]]></dc:creator><pubDate>Mon, 04 Feb 2019 06:15:33 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Fire dead and getting hot after testing Steppermodule and Servomodule together on Thu, 31 Jan 2019 17:48:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrtarantl" aria-label="Profile: mrtarantl">@<bdi>mrtarantl</bdi></a><br />
Did you use the cooling fan module as well?<br />
I glad you let us know what happened and sorry to hear about this mishap.</p>
]]></description><link>https://community.m5stack.com/post/2798</link><guid isPermaLink="true">https://community.m5stack.com/post/2798</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 31 Jan 2019 17:48:17 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Fire dead and getting hot after testing Steppermodule and Servomodule together on Thu, 31 Jan 2019 13:22:14 GMT]]></title><description><![CDATA[<p dir="auto">It's definitely cooked :D I just do not understand what happened and don't want anybody to have a dead esp as well :D</p>
]]></description><link>https://community.m5stack.com/post/2794</link><guid isPermaLink="true">https://community.m5stack.com/post/2794</guid><dc:creator><![CDATA[MrTarantl]]></dc:creator><pubDate>Thu, 31 Jan 2019 13:22:14 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Fire dead and getting hot after testing Steppermodule and Servomodule together on Thu, 31 Jan 2019 12:08:48 GMT]]></title><description><![CDATA[<p dir="auto">Did you try running them without the external power supply?<br />
Sound like it’s cooked!</p>
]]></description><link>https://community.m5stack.com/post/2792</link><guid isPermaLink="true">https://community.m5stack.com/post/2792</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 31 Jan 2019 12:08:48 GMT</pubDate></item></channel></rss>
