<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Stamp-S3 randomly starts drawing 500mA.]]></title><description><![CDATA[<p dir="auto">My Stamp-S3 seems to work fine, but regularly starts to suddenly draw 500mA for no apparent reason.</p>
<p dir="auto">This makes the unit too hot to touch.</p>
<p dir="auto">Even if I disconnect ALL pins, it still keeps drawing 500mA from the USB port.<br />
Only after unplugging, and reconnecting to USB, the powerdraw goes back to normal, at 10mA or so.</p>
<p dir="auto">Has anyone else seen the Stamp-S3 turn extremely hot at random times?</p>
]]></description><link>https://community.m5stack.com/topic/5617/stamp-s3-randomly-starts-drawing-500ma</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 23:56:41 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5617.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 30 Aug 2023 22:40:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Stamp-S3 randomly starts drawing 500mA. on Thu, 31 Aug 2023 15:56:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bram" aria-label="Profile: bram">@<bdi>bram</bdi></a> The EN is the Reset input and is pulled up normally, and brought down to reset the ESP.<br />
While it does seem odd that it is 5V, mine does the same thing!<br />
My (ahem) LilyGO T-Display S3 Reset pin is at 3.3, which makes more sense.<br />
-Terry</p>
]]></description><link>https://community.m5stack.com/post/22110</link><guid isPermaLink="true">https://community.m5stack.com/post/22110</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Thu, 31 Aug 2023 15:56:30 GMT</pubDate></item><item><title><![CDATA[Reply to Stamp-S3 randomly starts drawing 500mA. on Thu, 31 Aug 2023 05:05:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mtylerjr" aria-label="Profile: mtylerjr">@<bdi>mtylerjr</bdi></a> Thank you for that great diagnosis!</p>
<p dir="auto">I checked, and yes, I had a short.</p>
<p dir="auto">I fixed it, and hopefully I will not see the 0.5A power draw any more. I still have the 4.6V on EN pin, though, which I think is weird.</p>
<p dir="auto"><img src="https://imgur.com/gallery/sufbCZw" alt="short" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/22106</link><guid isPermaLink="true">https://community.m5stack.com/post/22106</guid><dc:creator><![CDATA[Bram]]></dc:creator><pubDate>Thu, 31 Aug 2023 05:05:34 GMT</pubDate></item><item><title><![CDATA[Reply to Stamp-S3 randomly starts drawing 500mA. on Thu, 31 Aug 2023 04:46:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mtylerjr" aria-label="Profile: mtylerjr">@<bdi>mtylerjr</bdi></a> Yes, I soldered the 2.54mm headers. I will check them again under my microscope.</p>
<p dir="auto">I also see a weird 4.6V on EN pin, whereas the VCC is a perfect 3.30V and the power is a 5.01V.</p>
]]></description><link>https://community.m5stack.com/post/22104</link><guid isPermaLink="true">https://community.m5stack.com/post/22104</guid><dc:creator><![CDATA[Bram]]></dc:creator><pubDate>Thu, 31 Aug 2023 04:46:54 GMT</pubDate></item><item><title><![CDATA[Reply to Stamp-S3 randomly starts drawing 500mA. on Thu, 31 Aug 2023 02:20:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bram" aria-label="Profile: bram">@<bdi>bram</bdi></a> Did you self-solder connectors and pins?</p>
<p dir="auto">Ive seen this a few times with tiny solder bridges to vcc or gnd that varied when they heated up/cooled down and acted exactly that way. (Or similarly when I took too long soldering pins, and damaged an internal component from the heat of the pin/solder pad)</p>
]]></description><link>https://community.m5stack.com/post/22101</link><guid isPermaLink="true">https://community.m5stack.com/post/22101</guid><dc:creator><![CDATA[mtylerjr]]></dc:creator><pubDate>Thu, 31 Aug 2023 02:20:33 GMT</pubDate></item></channel></rss>
