<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[UIflow2 ATOMS3 WIFI timeout when ENV3 attached to port A]]></title><description><![CDATA[<p dir="auto">Hi all,<br />
I was able to use UIflow2 Alpha-25-ATOMs3 to my ATOM controller and configure wifi, so I can deploy code from UIFlow2 online. But when I'm attaching the ENV3 module via PORTA (i2c interface) and restart the device the firmware starts, but it cannot fetch the wifi IP address and the message is timeout. When I remove ENV3 - all works fine. Any ideas?</p>
<p dir="auto">BTW I tried "Alpha-24" and other versions but it is the same behaviour :/</p>
<p dir="auto">Is there any way to debug it?<br />
Thanks</p>
]]></description><link>https://community.m5stack.com/topic/5646/uiflow2-atoms3-wifi-timeout-when-env3-attached-to-port-a</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 20:13:21 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5646.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 16 Sep 2023 18:18:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to UIflow2 ATOMS3 WIFI timeout when ENV3 attached to port A on Sun, 17 Sep 2023 07:31:12 GMT]]></title><description><![CDATA[<p dir="auto">Look in the Discussion about the ENV III and the Core S3</p>
]]></description><link>https://community.m5stack.com/post/22244</link><guid isPermaLink="true">https://community.m5stack.com/post/22244</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 17 Sep 2023 07:31:12 GMT</pubDate></item></channel></rss>
