<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Unit-ENV library for PlatformIO is not up-to-date]]></title><description><![CDATA[<p dir="auto">FYI, I discovered that the M5Unit-ENV library for PlatformIO is missing at least <a href="https://github.com/m5stack/M5Unit-ENV/commit/471f6869bb76c17a67d79acfc2e7bab464e39c36" target="_blank" rel="noopener noreferrer nofollow ugc">1 commit</a> compared to the one for the Arduino IDE, which is strange as they both advertise the same version: 0.0.8</p>
<p dir="auto">I suspect that 0.0.8 has been re-issued as the release date <a href="https://github.com/m5stack/M5Unit-ENV/releases/tag/0.0.8" target="_blank" rel="noopener noreferrer nofollow ugc">on GitHub</a> is from 2 weeks ago, an PlatformIO <a href="https://registry.platformio.org/libraries/m5stack/M5Unit-ENV" target="_blank" rel="noopener noreferrer nofollow ugc">m5stack/M5Unit-ENV</a> says: "Last Modified: a month ago"...</p>
<p dir="auto">In the meantime, if you need the latest version, you can use the GitHub URL instead of the name in your <code>lib_deps</code></p>
]]></description><link>https://community.m5stack.com/topic/5656/m5unit-env-library-for-platformio-is-not-up-to-date</link><generator>RSS for Node</generator><lastBuildDate>Fri, 01 May 2026 06:24:41 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5656.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 20 Sep 2023 11:16:49 GMT</pubDate><ttl>60</ttl></channel></rss>
