<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Lora868 Module and Cardkb]]></title><description><![CDATA[<p dir="auto">Hi new here. Trying to help my son with his M5Stack project. He is trying to use the Lora868 Module with the CardKB but there appears to be a conflict between the two, possible both trying use Pin33. He is using the Core2 and UIFlow. When both are added to a UIFlow project it gives the following error:</p>
<p dir="auto">Invalid Version<br />
File"&lt;string&gt;",line23,in &lt;module&gt;<br />
File"modules/.lora433.py",line 100, in config Lora433_ERROR:Invalid version.</p>
<p dir="auto">Any ideas would be greatly appreciated as he is set on using both the CardKB and the Lora686 module together.  Thank you.</p>
]]></description><link>https://community.m5stack.com/topic/5667/lora868-module-and-cardkb</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 01:00:14 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5667.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 24 Sep 2023 10:37:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Lora868 Module and Cardkb on Tue, 26 Sep 2023 00:05:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> thank you for the suggestion for Ext Port for Core2.</p>
]]></description><link>https://community.m5stack.com/post/22316</link><guid isPermaLink="true">https://community.m5stack.com/post/22316</guid><dc:creator><![CDATA[IsoEek]]></dc:creator><pubDate>Tue, 26 Sep 2023 00:05:16 GMT</pubDate></item><item><title><![CDATA[Reply to Lora868 Module and Cardkb on Sun, 24 Sep 2023 14:22:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> said in <a href="/post/22307">Lora868 Module and Cardkb</a>:</p>
<p dir="auto">Thank you for your reply. Will try the Ext Port for Core 2 module as that looks like it might work. Thanks again.</p>
]]></description><link>https://community.m5stack.com/post/22309</link><guid isPermaLink="true">https://community.m5stack.com/post/22309</guid><dc:creator><![CDATA[PK_Pippin]]></dc:creator><pubDate>Sun, 24 Sep 2023 14:22:05 GMT</pubDate></item><item><title><![CDATA[Reply to Lora868 Module and Cardkb on Sun, 24 Sep 2023 11:51:58 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/pk_pippin" aria-label="Profile: PK_Pippin">@<bdi>PK_Pippin</bdi></a></p>
<p dir="auto">you are correct, there is a conflict on GPIO33 which on M5Core2 is used for external I2C (SCL) and by the <a href="http://docs.m5stack.com/en/module/lora868" target="_blank" rel="noopener noreferrer nofollow ugc">Lora868 module</a> as CS.</p>
<p dir="auto">The reason is that on the original M5Stack (core) the same two GPIOs (21/22) were used for internal and external I2C. For M5Core2 the two I2C busses have been split and the external I2C now uses GPIO32/33.</p>
<p dir="auto">I guess one solution would be to switch to an M5Stack (core) instead of M5Core2 (core2).</p>
<p dir="auto">Another solution might be to use the <a href="https://docs.m5stack.com/en/module/extport_for_core2" target="_blank" rel="noopener noreferrer nofollow ugc">Ext Port for Core2</a> which gives you Port E (GPIO27/19) to use with the CardKB.</p>
<p dir="auto">Please note: While I did check in UIFlow 1.12.5 that Port E is offered for CardKB I do not have the necessary hardware to test either of my two proposed solutions. So there might be other issues I haven't foreseen.</p>
]]></description><link>https://community.m5stack.com/post/22307</link><guid isPermaLink="true">https://community.m5stack.com/post/22307</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 24 Sep 2023 11:51:58 GMT</pubDate></item></channel></rss>
