<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How can we use USB CDC on AtomS3 for serial debugging?]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I want to use the USB CDC port on AtomS3 (Lite) for serial debugging. It seems that there are no dedicated blocks for USB CDC in Alpha-26. Is it possible to use USB CDC with the <code>UART</code> blocks (e.g., <code>Init UART 0 with</code> or <code>UART 0 setup</code>) with a particular configuration?</p>
<p dir="auto">Thank you very much in advance,<br />
Shigeru</p>
]]></description><link>https://community.m5stack.com/topic/5700/how-can-we-use-usb-cdc-on-atoms3-for-serial-debugging</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 14:51:43 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5700.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 12 Oct 2023 11:37:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How can we use USB CDC on AtomS3 for serial debugging? on Wed, 25 Oct 2023 04:46:29 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I found that the <code>print</code> block in the <code>Text</code> category works fine without configuring pins.</p>
<p dir="auto"><img src="/assets/uploads/files/1698209134584-uiflow2_block_1698209027344.png" alt="0_1698209105851_uiflow2_block_1698209027344.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I overthought about this issue.</p>
<p dir="auto">Thanks,<br />
Shigeru</p>
]]></description><link>https://community.m5stack.com/post/22573</link><guid isPermaLink="true">https://community.m5stack.com/post/22573</guid><dc:creator><![CDATA[kotobuki]]></dc:creator><pubDate>Wed, 25 Oct 2023 04:46:29 GMT</pubDate></item></channel></rss>
