<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[8Encoder Issue &quot;tick&quot;]]></title><description><![CDATA[<p dir="auto"><strong>Hi there,</strong><br />
I got a new 8Encoder unit: very nice devie!<br />
However, I found a pretty anoying bug/ issue:<br />
It looks like turning one tick (mechanical resolution) give 2 increment/ decrement.<br />
It's possible to get 1 tick by hloding the knob between the ticks, but this is not permanent then...<br />
I guess that should be solvable with a firmware update?<br />
Is it possible to update the module? Bootloader?<br />
(I found SWD pads so I could flash the unit with a debugger...)<br />
My unit has Fw.Vers. 1.</p>
<p dir="auto">Kind regards,<br />
Stephan</p>
]]></description><link>https://community.m5stack.com/topic/5702/8encoder-issue-tick</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 11:29:16 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5702.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 12 Oct 2023 19:55:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 8Encoder Issue &quot;tick&quot; on Fri, 13 Oct 2023 02:30:22 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/amani" aria-label="Profile: Amani">@<bdi>Amani</bdi></a></p>
<p dir="auto">you can find the internal FW for the <a href="https://docs.m5stack.com/en/unit/8Encoder" target="_blank" rel="noopener noreferrer nofollow ugc">8Encoder</a> unit <a href="https://github.com/m5stack/M5Unit-8Encoder-Internal-FW" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
]]></description><link>https://community.m5stack.com/post/22452</link><guid isPermaLink="true">https://community.m5stack.com/post/22452</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 13 Oct 2023 02:30:22 GMT</pubDate></item></channel></rss>
