<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to power the M5stack Grey apart from USB-C and battery?]]></title><description><![CDATA[<p dir="auto">Hello,<br />
In my project, I'm using a 12V power source and I'd like to use it to power the M5Stack Grey. To do this, I've purchased a step-down converter to obtain 5V 1A from a 6-24V source. My problem is that I don't intend to use the USB-C port, which is far too complicated to adapt. Can I use the pins on the Grey's base, and if so, which ones? (those on the IO Port? or those on the Bus Port?) If not, do you have any other ideas?<br />
Supplementary question: if it's possible, will it recharge the battery?</p>
]]></description><link>https://community.m5stack.com/topic/5704/how-to-power-the-m5stack-grey-apart-from-usb-c-and-battery</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 11:29:16 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5704.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 12 Oct 2023 18:44:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to power the M5stack Grey apart from USB-C and battery? on Fri, 13 Oct 2023 02:48:46 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/alcor" aria-label="Profile: alcor">@<bdi>alcor</bdi></a></p>
<p dir="auto">please have a look at the <a href="https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/docs/schematic/Core/M5-Core-Schematic(20171206).pdf" target="_blank" rel="noopener noreferrer nofollow ugc">schematic</a>.</p>
<p dir="auto">With external 5 V you can power the M5Stack Gray either through the IO Port or the Bus Port. Use pins 5 V and GND (G).</p>
<p dir="auto">No, when powering the M5Stack with external 5 V, the battery will <strong>not</strong> be charged as this bypasses the TP5306 charger IC.</p>
]]></description><link>https://community.m5stack.com/post/22454</link><guid isPermaLink="true">https://community.m5stack.com/post/22454</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 13 Oct 2023 02:48:46 GMT</pubDate></item></channel></rss>
