<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core2 and VMeter]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I have an issue with the provided examples regarding the Core2 and the VMeter.</p>
<p dir="auto">I have tried all the examples I can find on the M5Stack Github but each have the same result, The Touch Screen stops responding to touch after programming and boot.</p>
<p dir="auto">I have confirmed that the Touch Screen still works correctly. By reprogramming the factory default sketch back into my Core2 and that functions correctly.</p>
<p dir="auto">What I am doing wrong?<br />
What I am overlooking?</p>
<p dir="auto">Any help will be much appreciated.</p>
<p dir="auto">Kind Regards<br />
Paul</p>
]]></description><link>https://community.m5stack.com/topic/5706/core2-and-vmeter</link><generator>RSS for Node</generator><lastBuildDate>Tue, 05 May 2026 18:32:43 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5706.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 13 Oct 2023 15:06:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Core2 and VMeter on Sun, 15 Oct 2023 11:06:23 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">Thank you for the guidance, I now have it "working" but had to change quite a bit of code.</p>
<p dir="auto">The Core2 download "pack" that I initially installed has completely different example code as well as the M5_AD1115 library has a few typo's in it so the examples don't compile to start.</p>
<p dir="auto">I now know not to trust the initial download "pack" and over write the separate library's with the library's for the separate GitHub library's, then check for Typo's.</p>
<p dir="auto">M5Stack should review every download "pack" to make sure all their examples work out the box, to avoid confusion.</p>
<p dir="auto">Now I have working code, all I wanted was to have a simple Volt Meter that I can build into a Test Fixture and read voltage back to a C# GUI, now the code from your links only shows a negative voltage, the only way to correct this is to swap the positive and negative connection points to my circuit I am wanting to measure.</p>
<p dir="auto">It's not ideal, but at least I have a working solution, Thank you again.</p>
]]></description><link>https://community.m5stack.com/post/22482</link><guid isPermaLink="true">https://community.m5stack.com/post/22482</guid><dc:creator><![CDATA[PaulB]]></dc:creator><pubDate>Sun, 15 Oct 2023 11:06:23 GMT</pubDate></item><item><title><![CDATA[Reply to Core2 and VMeter on Fri, 13 Oct 2023 18:45:06 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/paulb" aria-label="Profile: PaulB">@<bdi>PaulB</bdi></a></p>
<p dir="auto">have you also tried the <a href="https://github.com/m5stack/M5-ADS1115/blob/master/examples/Unit_VMeter_M5Core2/Unit_VMeter_M5Core2.ino" target="_blank" rel="noopener noreferrer nofollow ugc">example</a> linked from the VMeter <a href="https://docs.m5stack.com/en/unit/vmeter" target="_blank" rel="noopener noreferrer nofollow ugc">documents</a> page?</p>
<p dir="auto">Note: Unfortunately I do not have the VMeter unit so I cannot test it myself.</p>
]]></description><link>https://community.m5stack.com/post/22462</link><guid isPermaLink="true">https://community.m5stack.com/post/22462</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 13 Oct 2023 18:45:06 GMT</pubDate></item></channel></rss>
