<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Minimum temperature range for Cameras - UnitV K210 AI Camera and OV2640]]></title><description><![CDATA[<p dir="auto">Hello Community,</p>
<p dir="auto">I've been searching for information regarding the minimum temperature ranges for M5Stack camera modules, but I haven't been able to find this information anywhere.</p>
<p dir="auto">If anyone has any insights or information regarding the minimum temperature ranges for M5Stack camera modules, please share it with me. I want to use the camera module in extreme conditions during the winter.</p>
<p dir="auto">Your help in providing this information would be greatly appreciated. Thank you.</p>
]]></description><link>https://community.m5stack.com/topic/5717/minimum-temperature-range-for-cameras-unitv-k210-ai-camera-and-ov2640</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 06:08:14 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5717.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 18 Oct 2023 10:31:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Minimum temperature range for Cameras - UnitV K210 AI Camera and OV2640 on Fri, 20 Oct 2023 05:28:47 GMT]]></title><description><![CDATA[<p dir="auto">I don't know the exact specs and I have not tested. In my oppinion the battery will be the weak point. The small LiPo bag-batteries often go very weak below 0°C. You may remove it and power from external.<br />
The datasheet of the image sensor OV2640 says operating is allowed between -30°C and +70°C, stable image between 0°C and 50°C. for the other components you can find similar information in their data sheets.<br />
Make sure there is not too much humidity in air as it can condense on the electronic parts.<br />
It may help to pack the camera into thermal insulation so that it heats itself a bit over the environment. In extreme environment a small extra heating could help.</p>
]]></description><link>https://community.m5stack.com/post/22512</link><guid isPermaLink="true">https://community.m5stack.com/post/22512</guid><dc:creator><![CDATA[holofloh]]></dc:creator><pubDate>Fri, 20 Oct 2023 05:28:47 GMT</pubDate></item></channel></rss>
