<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to prevent firmware copy]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">What is the method to prevent code from being copied ?</p>
<p dir="auto">I read that it is easy to reverse to code from the memory, so using esp32 flash encryption should prevent that. Right?</p>
<p dir="auto">But then is it possible to upgrade the code ?</p>
<p dir="auto">If I use a webpage with esptool-js and .bin files, then the users can upgrade, but can I provide encrypted only files, and not the originals .bin ?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://community.m5stack.com/topic/5754/how-to-prevent-firmware-copy</link><generator>RSS for Node</generator><lastBuildDate>Fri, 01 May 2026 12:37:59 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5754.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 29 Oct 2023 21:13:00 GMT</pubDate><ttl>60</ttl></channel></rss>
