<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cardputer is broken under https:&#x2F;&#x2F;github.com&#x2F;m5stack&#x2F;M5Cardputer-UserDemo]]></title><description><![CDATA[<p dir="auto">Following the compiling instructions, Huge number of compiling errors.</p>
<p dir="auto">from /home/esp32/m5stack/M5Cardputer-UserDemo/main/apps/launcher/views/menu/menu.cpp:11:<br />
/home/esp32/esp/esp-idf/components/driver/deprecated/driver/i2s.h:27:2: warning: #warning "This set of I2S APIs has been deprecated, please include 'driver/i2s_std.h', 'driver/i2s_pdm.h' or 'driver/i2s_tdm.h' instead. if you want to keep using the old APIs and ignore this warning, you can enable 'Suppress leagcy driver deprecated warning' option under 'I2S Configuration' menu in Kconfig" [-Wcpp]<br />
27 | #warning "This set of I2S APIs has been deprecated, <br />
|  ^~~~~~~<br />
ninja: build stopped: subcommand failed.<br />
HINT: The issue is better to resolve by replacing format specifiers to 'PRI'-family macros (include &lt;inttypes.h&gt; header file).<br />
ninja failed with exit code 1, output of the command is in the /home/esp32/m5stack/M5Cardputer-UserDemo/build/log/idf_py_stderr_output_309207 and /home/esp32/m5stack/M5Cardputer-UserDemo/build/log/idf_py_stdout_output_309207</p>
<p dir="auto">Please advise what to do?<br />
Fortes83</p>
]]></description><link>https://community.m5stack.com/topic/5757/cardputer-is-broken-under-https-github-com-m5stack-m5cardputer-userdemo</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 06:08:15 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5757.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 30 Oct 2023 18:23:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cardputer is broken under https:&#x2F;&#x2F;github.com&#x2F;m5stack&#x2F;M5Cardputer-UserDemo on Tue, 31 Oct 2023 20:37:25 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/fortes83" aria-label="Profile: Fortes83">@<bdi>Fortes83</bdi></a></p>
<p dir="auto">which ESP-IDF version did you use?</p>
<p dir="auto">I found for the compilation to succeed ESP-IDF version <strong>v4.4.6</strong> (as stated <a href="https://github.com/m5stack/M5Cardputer-UserDemo/blob/main/README.md" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>) needs to be used.</p>
<p dir="auto">Note: I do not (yet) have a M5Cardputer so I cannot verify whether the resulting firmware image runs ok or not.</p>
]]></description><link>https://community.m5stack.com/post/22623</link><guid isPermaLink="true">https://community.m5stack.com/post/22623</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 31 Oct 2023 20:37:25 GMT</pubDate></item></channel></rss>
