<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Unable to verify flash chip connection]]></title><description><![CDATA[<p dir="auto">Hi, everyone. I'm getting the following when I try to upload a sketch to my m5Stack Core Basic:</p>
<p dir="auto">Sketch uses 230493 bytes (17%) of program storage space. Maximum is 1310720 bytes.<br />
Global variables use 20968 bytes (6%) of dynamic memory, leaving 306712 bytes for local variables. Maximum is 327680 bytes.<br />
<a href="http://esptool.py" target="_blank" rel="noopener noreferrer nofollow ugc">esptool.py</a> v4.5.1<br />
Serial port /dev/cu.usbserial-556E0263581<br />
Connecting.....<br />
Chip is ESP32-D0WDQ6-V3 (revision v3.0)<br />
Crystal is 40MHz<br />
MAC: b0:b2:1c:51:83:80<br />
Uploading stub...<br />
Running stub...<br />
Stub running...<br />
Changing baud rate to 921600<br />
Changed.</p>
<p dir="auto">A fatal error occurred: Unable to verify flash chip connection (Invalid head of packet (0xE0): Possible serial noise or corruption.).<br />
Failed uploading: uploading error: exit status 2</p>
<p dir="auto">I searched this forum for this, and I'm not optimistic this will be an easy fix, since I don't see anyone else running into this.</p>
<p dir="auto">This is just a blank sketch.</p>
<p dir="auto">Any thoughts on how to get around this? I'm on a Mac. Thanks!</p>
]]></description><link>https://community.m5stack.com/topic/5774/unable-to-verify-flash-chip-connection</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 10:40:47 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5774.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 04 Nov 2023 20:14:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Unable to verify flash chip connection on Tue, 03 Jun 2025 11:37:33 GMT]]></title><description><![CDATA[<p dir="auto">Try lowering the baud rate to 115200 in the upload settings—921600 can sometimes cause issues, especially on macOS. Also, double-check your USB cable (some are power-only), and try a different USB port or hub. If you're using a USB-C to serial adapter, that might be causing noise.</p>
]]></description><link>https://community.m5stack.com/post/29193</link><guid isPermaLink="true">https://community.m5stack.com/post/29193</guid><dc:creator><![CDATA[hacxx]]></dc:creator><pubDate>Tue, 03 Jun 2025 11:37:33 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to verify flash chip connection on Sun, 05 Nov 2023 13:36:14 GMT]]></title><description><![CDATA[<p dir="auto">SOLVED:</p>
<p dir="auto">I found the upload speed setting, and sure enough, that fixed it. Thanks!</p>
]]></description><link>https://community.m5stack.com/post/22657</link><guid isPermaLink="true">https://community.m5stack.com/post/22657</guid><dc:creator><![CDATA[hidarrin]]></dc:creator><pubDate>Sun, 05 Nov 2023 13:36:14 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to verify flash chip connection on Sun, 05 Nov 2023 13:32:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/teastain" aria-label="Profile: teastain">@<bdi>teastain</bdi></a> Thanks for the reply.</p>
<p dir="auto">I've tried multiple cables. Some high-end ones. No change.</p>
<p dir="auto">The default sketch that ships on the Core was giving me this error, so I wiped with esptool, and same error.</p>
<p dir="auto">How do I slow the upload speed?</p>
<p dir="auto">Thanks again.</p>
]]></description><link>https://community.m5stack.com/post/22656</link><guid isPermaLink="true">https://community.m5stack.com/post/22656</guid><dc:creator><![CDATA[hidarrin]]></dc:creator><pubDate>Sun, 05 Nov 2023 13:32:55 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to verify flash chip connection on Sat, 04 Nov 2023 23:54:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hidarrin" aria-label="Profile: hidarrin">@<bdi>hidarrin</bdi></a> Might try a slower upload speed or a better cable.<br />
What sketch is currently running in the Core, right now?<br />
A blank sketch needs  a delay, at least 100ms in the Loop or ideally a Serial print statement to test that the upload was in fact successful with the serial monitor.</p>
]]></description><link>https://community.m5stack.com/post/22652</link><guid isPermaLink="true">https://community.m5stack.com/post/22652</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Sat, 04 Nov 2023 23:54:08 GMT</pubDate></item></channel></rss>
