<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ATOM Lite with CANBus Unit - It&#x27;s possible?]]></title><description><![CDATA[<p dir="auto">Hello!</p>
<p dir="auto">I'm trying to use the ATOM Lite with the CANBus unit, but without success, I can't make it work. I've already tried using the firmware for both devices but it doesn't work.<br />
<img src="https://i.ibb.co/hmbb3ns/bd631c2c-f9f8-421f-abec-f02594d6ab6c.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">Firstly, I would like to know if it is possible to use this combination and if so, which GPIOS should I use to set the firmware's CAN communication.</p>
]]></description><link>https://community.m5stack.com/topic/5793/atom-lite-with-canbus-unit-it-s-possible</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 20:13:17 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5793.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 10 Nov 2023 13:57:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ATOM Lite with CANBus Unit - It&#x27;s possible? on Fri, 10 Nov 2023 14:45:43 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/filipe-dias" aria-label="Profile: Filipe-Dias">@<bdi>Filipe-Dias</bdi></a></p>
<p dir="auto">have you tried this <a href="https://github.com/m5stack/M5Atom/blob/master/examples/ATOM_BASE/ATOM_CAN/ATOM_CAN.ino#L47" target="_blank" rel="noopener noreferrer nofollow ugc">example</a> with the commented out GPIOs?</p>
]]></description><link>https://community.m5stack.com/post/22713</link><guid isPermaLink="true">https://community.m5stack.com/post/22713</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 10 Nov 2023 14:45:43 GMT</pubDate></item></channel></rss>
