<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Paper, SD card stuck]]></title><description><![CDATA[<p dir="auto">I have a brand new M5Paper and was just starting to work with jpg files on the SD card. My first attempts worked and the SD card entered and exited the slot easily enough. Then, after modifying my pictures I re-inserted the SD card and the picture didn't appear after running the sketch. I tried to eject the SD card by pushing it in, as usual, but it simply went into the casing. I cannot get the SD card out and it is blocking the way for another SD card in the slot. The only way I can think of to remove the card would be to open the case of the M5Paper. What is the best way to do that?</p>
]]></description><link>https://community.m5stack.com/topic/5797/m5paper-sd-card-stuck</link><generator>RSS for Node</generator><lastBuildDate>Fri, 01 May 2026 07:13:17 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5797.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 11 Nov 2023 11:34:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Paper, SD card stuck on Sat, 11 Nov 2023 19:48:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/steve1" aria-label="Profile: steve1">@<bdi>steve1</bdi></a> The case is normally only held together with clips around the edge. If you use two thin plates, you can open the clips.</p>
]]></description><link>https://community.m5stack.com/post/22726</link><guid isPermaLink="true">https://community.m5stack.com/post/22726</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 11 Nov 2023 19:48:18 GMT</pubDate></item></channel></rss>
