<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Solderless screw terminal proto base]]></title><description><![CDATA[<p dir="auto">Hi</p>
<p dir="auto">Has anyone got something that exposes the gpio pins as a screw terminal for more permanent solderless connection?</p>
<p dir="auto">I'm going to surface mount my m5stack into a box so you wont see the bottom of it.</p>
<p dir="auto">Rob</p>
]]></description><link>https://community.m5stack.com/topic/583/solderless-screw-terminal-proto-base</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 04:57:22 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/583.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 05 Feb 2019 02:53:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Solderless screw terminal proto base on Tue, 20 Aug 2024 19:43:11 GMT]]></title><description><![CDATA[<p dir="auto">@rob-biernat you can just make a Flat PCB, bigger than the M5 Stack,<br />
and place Terminals there.</p>
<p dir="auto">similar as it is done <a href="https://shop.m5stack.com/products/iot-learning-kit" target="_blank" rel="noopener noreferrer nofollow ugc">https://shop.m5stack.com/products/iot-learning-kit</a></p>
]]></description><link>https://community.m5stack.com/post/26179</link><guid isPermaLink="true">https://community.m5stack.com/post/26179</guid><dc:creator><![CDATA[franzhoepfinger]]></dc:creator><pubDate>Tue, 20 Aug 2024 19:43:11 GMT</pubDate></item></channel></rss>
