<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack Core 2 External WiFi antenna]]></title><description><![CDATA[<p dir="auto">Hello everyone,</p>
<p dir="auto">Has anyone here tried installing an external WiFi antenna on the M5Stack Core 2? The built-in 3D antenna provides fairly limited performance, and I'm thinking about trying to mount an antenna with an SMA connector. My questions are:</p>
<p dir="auto">Where on the PCB should I solder the wires for the SMA connector after removing the 3D antenna?<br />
Where can I find the PCB schematic for the Core 2?<br />
Any advice or experiences shared would be greatly appreciated!</p>
]]></description><link>https://community.m5stack.com/topic/5835/m5stack-core-2-external-wifi-antenna</link><generator>RSS for Node</generator><lastBuildDate>Thu, 30 Apr 2026 20:37:41 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5835.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 21 Nov 2023 14:59:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stack Core 2 External WiFi antenna on Tue, 02 Apr 2024 13:04:54 GMT]]></title><description><![CDATA[<p dir="auto">If you carefully look under the 3D antenna, you can see there are pre-soldered areas that look like for receiving an U.FL connector. Quite challenging to access to though. Maybe desolder the 3D antenna first.</p>
<p dir="auto"><img src="/assets/uploads/files/1712063033613-m5core2antenna-resized.jpeg" alt="0_1712063031987_m5Core2Antenna.jpeg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1712062993748-screenshot-2024-04-02-at-15.01.58-resized.png" alt="0_1712062991146_Screenshot 2024-04-02 at 15.01.58.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/24651</link><guid isPermaLink="true">https://community.m5stack.com/post/24651</guid><dc:creator><![CDATA[UnumDesignum]]></dc:creator><pubDate>Tue, 02 Apr 2024 13:04:54 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Core 2 External WiFi antenna on Wed, 22 Nov 2023 17:40:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/momopl" aria-label="Profile: momopl">@<bdi>momopl</bdi></a>,</p>
<p dir="auto">Most things M5Stack are split between store. and docs., so see <a href="https://docs.m5stack.com/en/core/core2" target="_blank" rel="noopener noreferrer nofollow ugc">here</a> for the schematic.</p>
<p dir="auto">I was curious, so I had a look inside my Core2 and it looks like there might even be a convenient breakout port for the SMA connector behind the label.</p>
<p dir="auto"><img src="/assets/uploads/files/1700674801997-img_1766.jpg" alt="0_1700674792861_IMG_1766.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/22863</link><guid isPermaLink="true">https://community.m5stack.com/post/22863</guid><dc:creator><![CDATA[gavin67890]]></dc:creator><pubDate>Wed, 22 Nov 2023 17:40:37 GMT</pubDate></item></channel></rss>
