<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[WiFi AP Connectivity UIFlow V2.0.0]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I am creating an app on a Core 2 device which requires Internet connectivity and using UIFlow V2.0.0 (Aplha-28). I cannot figure out how to connect to my WiFi network. In older versions of UIFlow, there apparently were "Network" functions, which had a connect to WiFi function. In Alpha-28, there are "WLAN AP" functions however, I have tried setting SSID and password, followed by "INIT WLAN AP" and I cannot seem to successfully compile and get my program working. I must be doing something incorrectly.</p>
<p dir="auto">Are there documents, tutorials and/or samples for UIFlow 2.0.0?  Would I be better off using Arduino tools and direct coding?</p>
<p dir="auto">Thank you</p>
]]></description><link>https://community.m5stack.com/topic/5844/wifi-ap-connectivity-uiflow-v2-0-0</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 17:15:39 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5844.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 23 Nov 2023 14:58:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to WiFi AP Connectivity UIFlow V2.0.0 on Mon, 27 Nov 2023 19:17:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bergkatse" aria-label="Profile: bergkatse">@<bdi>bergkatse</bdi></a> I managed to resolve some of the issues that I was having and, implemented MQTT into my Core 2 monitoring. I stuck with UIFlow for this initial application to see how capable it was. It's not too bad however, I believe I will move to the Arduino IDE for more control. Here is the M5Stack Core 2 app that I created for your reference:</p>
<p dir="auto"><img src="/assets/uploads/files/1701112443929-cb317c54-58c7-404a-ae59-e84bf132f4c9-image-resized.png" alt="0_1701112507127_cb317c54-58c7-404a-ae59-e84bf132f4c9-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I'm note sure if I implemented the WLAN functionality properly however, it works under all conditions. For example, if I exit the area of WiFi coverage, the connection resumes when I get back into range.</p>
]]></description><link>https://community.m5stack.com/post/22912</link><guid isPermaLink="true">https://community.m5stack.com/post/22912</guid><dc:creator><![CDATA[gminich]]></dc:creator><pubDate>Mon, 27 Nov 2023 19:17:01 GMT</pubDate></item><item><title><![CDATA[Reply to WiFi AP Connectivity UIFlow V2.0.0 on Fri, 24 Nov 2023 04:09:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bergkatse" aria-label="Profile: bergkatse">@<bdi>bergkatse</bdi></a> Thank you for your reply, it sent me in the right direction. I will admit, this platform does not have the best documentation. Items such as this require hit-and-miss troubleshooting. I have experienced strange initialization issues with other sensors and simply moving the block of initialization code resolved the issue.</p>
<p dir="auto">I was able to get around WiFi INIT issue based on your suggestion however, I am unable to connect to my WiFi network. I'll keep trying and if I'm successful, I'll try connecting while not connected to USB to see if I experience the same issue as you are having.</p>
]]></description><link>https://community.m5stack.com/post/22875</link><guid isPermaLink="true">https://community.m5stack.com/post/22875</guid><dc:creator><![CDATA[gminich]]></dc:creator><pubDate>Fri, 24 Nov 2023 04:09:10 GMT</pubDate></item><item><title><![CDATA[Reply to WiFi AP Connectivity UIFlow V2.0.0 on Thu, 23 Nov 2023 23:16:29 GMT]]></title><description><![CDATA[<p dir="auto">You should init the WLAN AP first, then connect.</p>
<p dir="auto">But I am having a similar problem. When connected via USB, everything works great. When I run the same program without USB connected, I get a wifi oserror, and attempts to have my StickC+ talk to my desktop via MQTT don't work at all. It won't even load the Widgets to set screen parameters on the StickC+. It's like the Wifi connection is only allowed to work for UIflow??</p>
]]></description><link>https://community.m5stack.com/post/22874</link><guid isPermaLink="true">https://community.m5stack.com/post/22874</guid><dc:creator><![CDATA[BergKatse]]></dc:creator><pubDate>Thu, 23 Nov 2023 23:16:29 GMT</pubDate></item></channel></rss>
