<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cardputer &amp; Sensors]]></title><description><![CDATA[<p dir="auto">Hi all</p>
<p dir="auto">Not sure if this is the correct forum but I have had my Cardputer delivered and wondered if I could use my Core2 and 3 sensors with it?  It doesn't seem to have a Port A,B etc.</p>
<p dir="auto">Steve</p>
]]></description><link>https://community.m5stack.com/topic/5849/cardputer-sensors</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 17:15:15 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5849.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 27 Nov 2023 11:39:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cardputer &amp; Sensors on Mon, 27 Nov 2023 19:36:27 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the replies everyone.</p>
]]></description><link>https://community.m5stack.com/post/22913</link><guid isPermaLink="true">https://community.m5stack.com/post/22913</guid><dc:creator><![CDATA[Bipman]]></dc:creator><pubDate>Mon, 27 Nov 2023 19:36:27 GMT</pubDate></item><item><title><![CDATA[Reply to Cardputer &amp; Sensors on Mon, 27 Nov 2023 16:55:46 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/bipman" aria-label="Profile: Bipman">@<bdi>Bipman</bdi></a></p>
<p dir="auto">by default Port A is meant for I2C, but it can be used for I/O (Port B) or UART (Port C) as well.</p>
<p dir="auto">Note: But please be aware, that it can be only one type of port at any given time. Also, since its default use is Port A (I2C) there are internal pull-up resistors (10 k) in place on both lines which might have a negative effect when used in a different mode.</p>
<p dir="auto">If you need Port A and Port B at the same time there is the <a href="https://docs.m5stack.com/en/unit/pbhub_1.1" target="_blank" rel="noopener noreferrer nofollow ugc">PbHUB unit</a> which can be used to connect some of the Port B units.</p>
<p dir="auto">If you need all three types of ports (A, B and C) together then I am afraid M5Cardputer is the wrong device to use as core. There are simply no more GPIOs available for a dedicated Port B and/or Port C. Please see schematic <a href="https://docs.m5stack.com/en/core/Cardputer" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
]]></description><link>https://community.m5stack.com/post/22908</link><guid isPermaLink="true">https://community.m5stack.com/post/22908</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 27 Nov 2023 16:55:46 GMT</pubDate></item><item><title><![CDATA[Reply to Cardputer &amp; Sensors on Mon, 27 Nov 2023 16:10:23 GMT]]></title><description><![CDATA[<p dir="auto">Hi</p>
<p dir="auto">Some sensors only use port B,C etc. so not sure how I would connect those.</p>
]]></description><link>https://community.m5stack.com/post/22907</link><guid isPermaLink="true">https://community.m5stack.com/post/22907</guid><dc:creator><![CDATA[Bipman]]></dc:creator><pubDate>Mon, 27 Nov 2023 16:10:23 GMT</pubDate></item><item><title><![CDATA[Reply to Cardputer &amp; Sensors on Mon, 27 Nov 2023 14:48:21 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/bipman" aria-label="Profile: Bipman">@<bdi>Bipman</bdi></a></p>
<p dir="auto">the Cardputer does have a Port A on the side like most cores. See documentation <a href="https://docs.m5stack.com/en/core/Cardputer" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
]]></description><link>https://community.m5stack.com/post/22906</link><guid isPermaLink="true">https://community.m5stack.com/post/22906</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 27 Nov 2023 14:48:21 GMT</pubDate></item></channel></rss>
