<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Lesson 14.2. UI Flow. Burning with Mac]]></title><description><![CDATA[<h3>The purpose of this lesson</h3>
<p dir="auto">Hi! Today we will learn how to flash M5 using macOS (figure 1).</p>
<p dir="auto"><img src="https://pp.userapi.com/c850528/v850528108/a99f4/0U_BgPIgocU.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 1</p>
<p dir="auto">This lesson will teach you how to: update the M5 firmware using the macOS operating system.</p>
<h2>Let's start!</h2>
<p dir="auto">The first thing to do is to visit the official website <a href="https://m5stack.com" title="https://m5stack.com" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.com</a>, then select Explore [1] (figure 2), Download [2] from the top menu.</p>
<p dir="auto"><img src="https://pp.userapi.com/c850624/v850624108/acf0f/uu0UtjT2cPo.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 2</p>
<p dir="auto">The first thing to download is the driver [1] (figure 3) and the program [2].</p>
<p dir="auto"><img src="https://pp.userapi.com/c846324/v846324375/18fd55/DrGfYJiNEW4.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 3</p>
<p dir="auto">Once the driver download is complete. Open the file as shown in figure 4.</p>
<p dir="auto"><img src="https://pp.userapi.com/c845219/v845219375/19bf33/GhZ8HlhPOUU.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 4</p>
<p dir="auto">Proceed according to the screenshots in figures 5-5.6.</p>
<p dir="auto"><img src="https://pp.userapi.com/c850232/v850232375/d2128/HdmRbd6Y3hE.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 5</p>
<p dir="auto"><img src="https://pp.userapi.com/c850232/v850232375/d2130/zdv35FYxClQ.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 5.1</p>
<p dir="auto"><img src="https://pp.userapi.com/c850232/v850232375/d2138/WaE3r_lVIqw.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 5.2</p>
<p dir="auto"><img src="https://pp.userapi.com/c850232/v850232375/d213f/HuDC1B0PXnU.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 5.3</p>
<p dir="auto"><img src="https://pp.userapi.com/c850232/v850232375/d2147/ZlfumB7OvdA.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 5.4</p>
<p dir="auto"><img src="https://pp.userapi.com/c850232/v850232375/d214f/ySN9eG9UV20.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 5.5</p>
<p dir="auto"><img src="https://pp.userapi.com/c850232/v850232375/d2157/pGEQ0BSsKIM.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 5.6</p>
<p dir="auto">Great! Drivers are installed. You must now allow the operating system to run third-party applications. To do this, open the search [1] (figure 6), then find the <strong>Terminal application.app</strong> and start it by pressing <strong>Enter</strong> [2].</p>
<p dir="auto"><img src="https://pp.userapi.com/c844722/v844722375/19f246/tZjfIx_nKjs.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 6</p>
<p dir="auto">Now write the line below and press <strong>Enter</strong> (figure 6.1).</p>
<pre><code>sudo spctl --master-disable
<p dir="auto"><img src="https://pp.userapi.com/c844722/v844722375/19f24f/pqPhRS9mQIk.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 6.1</p>
<p dir="auto">Good! Now click on the Apple in the upper left corner [1] (figure 6.2), then open <strong>System Preferences...</strong> [2], then open <strong>Security &amp; Privacy</strong> [3].</p>
<p dir="auto"><img src="https://pp.userapi.com/c844722/v844722375/19f258/N98b9s17Ic8.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 6.2</p>
<p dir="auto">Make sure you have the radio check box set to <strong>Anywhere</strong> (if not, check it) (figure 6.3).</p>
<p dir="auto"><img src="https://pp.userapi.com/c844722/v844722375/19f260/WLfVxt7U0I4.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 6.3</p>
<p dir="auto">Now go back to the browser to downloads [1] (figure 7) and open the file with the Ctrl key pressed [2].</p>
<p dir="auto"><img src="https://pp.userapi.com/c844723/v844723426/1971e2/DEiF_pZ3AX4.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 7</p>
<p dir="auto">So, now connect your device to your Mac with a USB cable. Select the most current SOFTWARE version and click on the <strong>Flash</strong> [1] button (figure 7.1). At the end of the process, the indicator will be completely painted [2].</p>
<p dir="auto"><img src="https://pp.userapi.com/c844723/v844723426/1971ea/bBy4iMkoDP4.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 7.1</p>
<p dir="auto">Once the device is flashed - disconnect the cable from the Mac and press the red button (the same power button) on the M5. That's it!</p>
<h3>Downloads</h3>
<p dir="auto">Alas, there is nothing here today :)</p>
]]></description><link>https://community.m5stack.com/topic/586/lesson-14-2-ui-flow-burning-with-mac</link><generator>RSS for Node</generator><lastBuildDate>Thu, 30 Apr 2026 17:41:10 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/586.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 06 Feb 2019 10:39:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Lesson 14.2. UI Flow. Burning with Mac on Wed, 18 Mar 2020 04:51:38 GMT]]></title><description><![CDATA[<p dir="auto">This information is outdated anyway, you can flash the firmware on mac using the firmware burner tool within uiflow desktop version</p>
]]></description><link>https://community.m5stack.com/post/7801</link><guid isPermaLink="true">https://community.m5stack.com/post/7801</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Wed, 18 Mar 2020 04:51:38 GMT</pubDate></item><item><title><![CDATA[Reply to Lesson 14.2. UI Flow. Burning with Mac on Wed, 18 Mar 2020 03:24:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dimi" aria-label="Profile: dimi">@<bdi>dimi</bdi></a> The illustrations are missing from this page.</p>
]]></description><link>https://community.m5stack.com/post/7799</link><guid isPermaLink="true">https://community.m5stack.com/post/7799</guid><dc:creator><![CDATA[RschDev]]></dc:creator><pubDate>Wed, 18 Mar 2020 03:24:33 GMT</pubDate></item></channel></rss>
