<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[SIM7080G as a Wifi AP]]></title><description><![CDATA[<p dir="auto">Hi<br />
I´m a little confused here.</p>
<p dir="auto"><a href="https://shop.m5stack.com/products/sim7080g-cat-m-nb-iot-unit" target="_blank" rel="noopener noreferrer nofollow ugc">https://shop.m5stack.com/products/sim7080g-cat-m-nb-iot-unit</a></p>
<p dir="auto">Is there a chance, this unit by itself, or either with an Atom Lite connected, could act as a Wifi Router?</p>
<p dir="auto">We are trying to connect multiple devices on Atom Lite, to HiveMQ, but we need to provide mobile internet access to the ESP32´s</p>
<p dir="auto">Thanks</p>
]]></description><link>https://community.m5stack.com/topic/5897/sim7080g-as-a-wifi-ap</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 00:09:35 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5897.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 18 Dec 2023 19:59:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to SIM7080G as a Wifi AP on Tue, 19 Dec 2023 10:09:46 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/fbritop" aria-label="Profile: fbritop">@<bdi>fbritop</bdi></a>,</p>
<p dir="auto">The unit is just a comms module i.e. it would need a controller like the Atom Lite. In terms of connecting to HiveMQ it could be used to send out MQTT requests. Perhaps you could expand what you are trying to achieve.</p>
<p dir="auto">If you have many devices (taking to mean sensors) connected to a Atom Lite controller then this could gather readings and send from a single Atom Lite plugged into this module.</p>
<p dir="auto">If you have many devices (taking to mean Atom Lites) and you want to concentrate to a single mobile access point. It could probably be done by connecting one Atom to a 7080G unit and then relay from other Atom Lites, but a commonly available Mobile Hotspot (e.g. 5G) device to connect all the Atoms via Wi-Fi would probably be better.</p>
<p dir="auto">The benefit of this device is its low power consumption and design for mobile data at relatively low volumes (see LTE-M and NB-IoT).</p>
<p dir="auto">As an example, I have a Core2 and IoT base configured to simply request the current CO2 from electricity production once a day and display it. The SIM costs are minimal a few pounds per year, not per month. It is completely standalone, apart from power. For example, I have used it to collect button presses on a micro: bit via serial and relay them to AWS.</p>
]]></description><link>https://community.m5stack.com/post/23085</link><guid isPermaLink="true">https://community.m5stack.com/post/23085</guid><dc:creator><![CDATA[gavin67890]]></dc:creator><pubDate>Tue, 19 Dec 2023 10:09:46 GMT</pubDate></item></channel></rss>
