<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Erase UIFlow 2 from M5Dial]]></title><description><![CDATA[<p dir="auto">Dears</p>
<p dir="auto">I'd like to erase the installed UIFlow 2 with the M5Burner or with PlatformIO. Unfortunately,  after hundreds of trials I'm still not able to remove the image.</p>
<p dir="auto">What I did so fare:</p>
<p dir="auto">Opened the m5burner and pressed the burn button and in the dialog pressed the erase button. Bevor a I'd like to bring the stamp into the upload mode with pressed the BT0, afterwards, a klick on the reset button. I've got the error message:<br />
"A fatal error occurred: Failed to connect to Espressif device: No serial data received. "</p>
<p dir="auto">Doing the same with the PlattformIO, press BTO and klick the reset button, but still not possible to remove or erase the installed firmware.</p>
<p dir="auto">thanks for your help!</p>
]]></description><link>https://community.m5stack.com/topic/5906/erase-uiflow-2-from-m5dial</link><generator>RSS for Node</generator><lastBuildDate>Sun, 03 May 2026 08:49:12 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5906.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 21 Dec 2023 20:19:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Erase UIFlow 2 from M5Dial on Sat, 23 Dec 2023 20:34:07 GMT]]></title><description><![CDATA[<p dir="auto">indeed, is very stiff, but now it works. thanks a lot gents.</p>
]]></description><link>https://community.m5stack.com/post/23128</link><guid isPermaLink="true">https://community.m5stack.com/post/23128</guid><dc:creator><![CDATA[haeberle]]></dc:creator><pubDate>Sat, 23 Dec 2023 20:34:07 GMT</pubDate></item><item><title><![CDATA[Reply to Erase UIFlow 2 from M5Dial on Fri, 22 Dec 2023 06:26:52 GMT]]></title><description><![CDATA[<p dir="auto">Ok so just tested and you have to hold the button on the stamp in (very stiff) and then pug in.<br />
M5Burner will pup up a blue box to say device detected.</p>
<p dir="auto">If that doesn't work, remove the retension plate holding the Stamp in, gently lift out the stamp, remove the voter to access the button and then try again.</p>
<p dir="auto">The orange plastic is stiff compared to the gray plastic cover.</p>
]]></description><link>https://community.m5stack.com/post/23117</link><guid isPermaLink="true">https://community.m5stack.com/post/23117</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 22 Dec 2023 06:26:52 GMT</pubDate></item><item><title><![CDATA[Reply to Erase UIFlow 2 from M5Dial on Thu, 21 Dec 2023 22:35:48 GMT]]></title><description><![CDATA[<p dir="auto">Hi Felix</p>
<p dir="auto">no success, also tried with another PC and PlatformIO. Maybe the button is broken</p>
]]></description><link>https://community.m5stack.com/post/23115</link><guid isPermaLink="true">https://community.m5stack.com/post/23115</guid><dc:creator><![CDATA[haeberle]]></dc:creator><pubDate>Thu, 21 Dec 2023 22:35:48 GMT</pubDate></item><item><title><![CDATA[Reply to Erase UIFlow 2 from M5Dial on Thu, 21 Dec 2023 21:35:09 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/haeberle" aria-label="Profile: haeberle">@<bdi>haeberle</bdi></a></p>
<p dir="auto">from the M5Dial <a href="https://docs.m5stack.com/en/core/M5Dial" target="_blank" rel="noopener noreferrer nofollow ugc">documentation</a>: <em>If you want to enter download mode, press and hold the G0 button on StampS3 before turning it on, then release it after powering it on.</em></p>
<p dir="auto">Translation: unplug USB, press and hold G0 button, plug USB, release G0 button -&gt; M5Dial should now be in download mode.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> : M5Dial (and other M5StampS3 based cores) do <strong>not</strong> have the download mechanism with the green LED.</p>
]]></description><link>https://community.m5stack.com/post/23114</link><guid isPermaLink="true">https://community.m5stack.com/post/23114</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 21 Dec 2023 21:35:09 GMT</pubDate></item><item><title><![CDATA[Reply to Erase UIFlow 2 from M5Dial on Thu, 21 Dec 2023 20:52:58 GMT]]></title><description><![CDATA[<p dir="auto">Thanks, followed your approach, but didn't work. No green led comes up.</p>
<p dir="auto">Means plug in, press BTNO on the stamps3 and waited for 4 or more seconds.  Also open ed M5Burner between the plug in and the pressed the button, or also tried to have m5burner already open, all variations have no success.</p>
]]></description><link>https://community.m5stack.com/post/23113</link><guid isPermaLink="true">https://community.m5stack.com/post/23113</guid><dc:creator><![CDATA[haeberle]]></dc:creator><pubDate>Thu, 21 Dec 2023 20:52:58 GMT</pubDate></item><item><title><![CDATA[Reply to Erase UIFlow 2 from M5Dial on Thu, 21 Dec 2023 20:36:19 GMT]]></title><description><![CDATA[<p dir="auto">you need to plug the dial in, open M5Burner and hold the button for 4 seconds until a green led comes on to get it into boot mode.<br />
It does take some practice to get the timing correct.</p>
]]></description><link>https://community.m5stack.com/post/23112</link><guid isPermaLink="true">https://community.m5stack.com/post/23112</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 21 Dec 2023 20:36:19 GMT</pubDate></item></channel></rss>
