<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[AtomS3 0.85&quot; OLED unable to wake from buttom]]></title><description><![CDATA[<p dir="auto">Recently tried using the AtomS3 with 0.85" OLED for a CAN-bus project and it seems like a missed opportunity to not have the (only) button under OLED connected to a pin that support waking up the ESP.</p>
<p dir="auto">Is there an easy workaround for this?</p>
<p dir="auto">I would also have to find a way to put the isolated CAN bus base to sleep to make this project viable with M5Stack products so I guess odds are I'll have to make my own, but I would be nice if new products were designed with deep sleep and power saving in mind.</p>
]]></description><link>https://community.m5stack.com/topic/5935/atoms3-0-85-oled-unable-to-wake-from-buttom</link><generator>RSS for Node</generator><lastBuildDate>Wed, 06 May 2026 17:37:20 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5935.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 01 Jan 2024 18:41:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to AtomS3 0.85&quot; OLED unable to wake from buttom on Wed, 05 Jun 2024 00:18:06 GMT]]></title><description><![CDATA[<p dir="auto">I'm not able to get<br />
<a href="https://docs.m5stack.com/en/atom/Atomic%20CAN%20Base" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/atom/Atomic CAN Base</a><br />
to work with the AtomS3, immediately <code>TWAI_ALERT_ERR_PASS, TWAI_ALERT_BUS_ERROR</code></p>
<p dir="auto"><a href="https://docs.m5stack.com/en/unit/can" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/unit/can</a><br />
works, though.<br />
What CAN library did you use? With what pin definitions?</p>
<p dir="auto">Thanks in advance!</p>
]]></description><link>https://community.m5stack.com/post/25493</link><guid isPermaLink="true">https://community.m5stack.com/post/25493</guid><dc:creator><![CDATA[sonic]]></dc:creator><pubDate>Wed, 05 Jun 2024 00:18:06 GMT</pubDate></item><item><title><![CDATA[Reply to AtomS3 0.85&quot; OLED unable to wake from buttom on Sat, 06 Jan 2024 12:23:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/teastain" aria-label="Profile: teastain">@<bdi>teastain</bdi></a> but G41 isnt supported as a wake-up pin from deep sleep - when the AtomS3 has a ton of free pins this seems like something that could be adressed in a future revision to make the product more usable.</p>
]]></description><link>https://community.m5stack.com/post/23250</link><guid isPermaLink="true">https://community.m5stack.com/post/23250</guid><dc:creator><![CDATA[notsonominal]]></dc:creator><pubDate>Sat, 06 Jan 2024 12:23:10 GMT</pubDate></item><item><title><![CDATA[Reply to AtomS3 0.85&quot; OLED unable to wake from buttom on Mon, 01 Jan 2024 20:09:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/notsonominal" aria-label="Profile: notsonominal">@<bdi>notsonominal</bdi></a> G41 is the input from the button into your program.<br />
You can read that button and do whatever your program needs, even transfer the input directly to an output.<br />
:)</p>
]]></description><link>https://community.m5stack.com/post/23206</link><guid isPermaLink="true">https://community.m5stack.com/post/23206</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Mon, 01 Jan 2024 20:09:16 GMT</pubDate></item></channel></rss>
