<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ENV IV: problem with pressure]]></title><description><![CDATA[<p dir="auto">I habe connected an ENV IV on my Core2 und use the examplecode in UIFlow. On the Core2 is a pressure about 927hPa displayed. The real pressure is about 1005hPa. The core2 with the ENV IV ist running more than 10 hours, on change.</p>
<p dir="auto">Is there any solution?</p>
]]></description><link>https://community.m5stack.com/topic/5961/env-iv-problem-with-pressure</link><generator>RSS for Node</generator><lastBuildDate>Tue, 05 May 2026 01:44:48 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5961.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 08 Jan 2024 22:09:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ENV IV: problem with pressure on Sun, 14 Jan 2024 21:18:08 GMT]]></title><description><![CDATA[<p dir="auto">Problem solved: the air pressure is calculated the the altitude of 0m, when the pressure is measured for example in the alps ( as i did) in 800m height, it‘ s signifikant lower.</p>
]]></description><link>https://community.m5stack.com/post/23348</link><guid isPermaLink="true">https://community.m5stack.com/post/23348</guid><dc:creator><![CDATA[Winni]]></dc:creator><pubDate>Sun, 14 Jan 2024 21:18:08 GMT</pubDate></item></channel></rss>
