<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Kernel crashed when rotate the M5dial encoder fast]]></title><description><![CDATA[<p dir="auto">Hi Team</p>
<p dir="auto">I was working on a small BLE-related project with M5Dial.<br />
Basically, the code allows you to select services with M5Dial's encoder, then press btnA to advertise it and hold the btnA to stop advertising.</p>
<p dir="auto">The code works just fine when you rotate the encoder slowly, but when you do it fast, it will throw following Errors  randomly</p>
<pre><code>TypeError: '' object isn't callable。
TypeError: 'dict_view' object isn't callable
TypeError: 'list' object isn't callable
<p dir="auto">or the kernel crashed and the device been reset.</p>
<p dir="auto">firmware Version: UIFlow alpha-29</p>
<pre><code>import ubluetooth
import time
from M5 import Widgets, Speaker, BtnA, update
from hardware import Rotary
class BLE_SERVER():
    def __init__(self,src_boards,dst_boards):
        self.ble = ubluetooth.BLE()
        self.isAdvertising=False
        self.rotary = Rotary()
        self.DST_APPS=dst_boards
        self.label0 = Widgets.Label("label0", 16, 101, 1.0, 0xf2f805, 0x000000, Widgets.FONTS.DejaVu24)
        Speaker.setVolumePercentage(0.3)
        Widgets.setBrightness(10)
        BtnA.setCallback(type=BtnA.CB_TYPE.WAS_CLICKED, cb=self.btnA_wasClicked_event)
        BtnA.setCallback(type=BtnA.CB_TYPE.WAS_HOLD, cb=self.btnA_wasHold_event)
    def btnA_wasClicked_event(self,state):
        try:
            if not self.isAdvertising:
                print('click0')
                self.isAdvertising = True
                self.label0.setText(str('advertising....'))
                self.label0.setCursor(x=20, y=100)
                self.label0.setVisible(True)
                Widgets.setBrightness(1)
                adv_app=self.DST_APPS[int((self.rotary.get_rotary_value()) % len(self.DST_APPS) - 1)]
                self.start_advertising(adv_app)
        except Exception as e:
            print('btnA_Clicked:',repr(e))
    def btnA_wasHold_event(self,state):
        try:
            if self.isAdvertising:
                print('hold0')
                self.isAdvertising = False
                self.label0.setText(str('adv stoped'))
                self.ble.gap_advertise(None)
            print('btnA_Holded: ',repr(e))
    def bt_irq(self,event, data):
        print('BLE_EVENT: ', event)
    def start_advertising(self,app):
        for i in range(3):
            try:
                SERVICE_UUID_SIM = ubluetooth.UUID(0xfff0)
                RX_UUID_SIM = ubluetooth.UUID(0xfff1)
                TX_UUID_SIM = ubluetooth.UUID(0xfff2)
                SERVICE_NAME_SIM = app
                CHAR_RX = (RX_UUID_SIM, ubluetooth.FLAG_WRITE | 0x04)
                CHAR_TX = (TX_UUID_SIM, ubluetooth.FLAG_NOTIFY)
                SERVICE_1 = (SERVICE_UUID_SIM, (CHAR_RX, CHAR_TX,) ,)
                SERVICES = (SERVICE_1,)
                time.sleep(0.5)
                self.ble.config(gap_name=app, addr_mode=1)
                adv_data_prefix = [0x02,0x01,0x06,len(SERVICE_NAME_SIM)+1, 0x09]
                resp_d = b'\x11\x07'  + bytes(SERVICE_UUID_SIM)
                ((char_rx, self.char_tx), ) = self.ble.gatts_register_services(SERVICES)
                self.ble.gap_advertise(100,adv_data = bytes(adv_data_prefix) + SERVICE_NAME_SIM.encode('utf-8'),resp_data = resp_d)
                print('start BLE advertising: ',app)
                break
                print('------------------------------------------advertising: ',repr(e))
                time.sleep(3)
    def run(self):
        self.ble.active(True)
        self.ble.irq(self.bt_irq)  #CB
        list2 = [0xff0000, 0xff9900, 0xffff00, 0x33ff33, 0x33ffff, 0x3333ff, 0xcc33cc]
        while True:
            update()
            if not self.isAdvertising and (self.rotary.get_rotary_status()):
                print(time.ticks_ms())
                Speaker.tone(3000, 50)
                Widgets.fillScreen(list2[int((self.rotary.get_rotary_value()) % len(self.DST_APPS) - 1)])
                self.label0.setText(self.DST_APPS[int((self.rotary.get_rotary_value()) % len(self.DST_APPS) - 1)])
            time.sleep(0.1)
if __name__ == '__main__':
    u = BLE_SERVER(['A','B'],['BLE_C','BLE_D'])
    u.run()
<pre><code>&lt;========  after the code run, rotate the encoder fastly for 50+ times.
26733
26859
27183
27409
click0
start BLE advertising:  BLE_C
&lt;==  hold btnA here, but get an error.
<pre><code>93335
click0
&lt;&lt;=======    hold btnA here, but kernel crashed.
PROBLEM IN THONNY'S BACK-END: Exception while handling 'run' (ConnectionError: read failed: [Errno 6] Device not configured).
See Thonny's backend.log for more info.
You may need to press "Stop/Restart" or hard-reset your MicroPython device and try again.
]]></description><link>https://community.m5stack.com/topic/5992/kernel-crashed-when-rotate-the-m5dial-encoder-fast</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 15:36:51 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5992.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 18 Jan 2024 00:01:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Kernel crashed when rotate the M5dial encoder fast on Fri, 19 Jan 2024 12:41:05 GMT]]></title><description><![CDATA[<p dir="auto">Hi guys</p>
<p dir="auto">thank you for the insight - good to know.</p>
]]></description><link>https://community.m5stack.com/post/23404</link><guid isPermaLink="true">https://community.m5stack.com/post/23404</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 19 Jan 2024 12:41:05 GMT</pubDate></item><item><title><![CDATA[Reply to Kernel crashed when rotate the M5dial encoder fast on Fri, 19 Jan 2024 07:40:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/codeblue" aria-label="Profile: codeblue">@<bdi>codeblue</bdi></a> It will be fixed in the next version.</p>
]]></description><link>https://community.m5stack.com/post/23395</link><guid isPermaLink="true">https://community.m5stack.com/post/23395</guid><dc:creator><![CDATA[lbuque]]></dc:creator><pubDate>Fri, 19 Jan 2024 07:40:17 GMT</pubDate></item><item><title><![CDATA[Reply to Kernel crashed when rotate the M5dial encoder fast on Fri, 19 Jan 2024 06:09:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lbuque" aria-label="Profile: lbuque">@<bdi>lbuque</bdi></a> said in <a href="/post/23388">Kernel crashed when rotate the M5dial encoder fast</a>:</p>
<p dir="auto">setCallback</p>
<p dir="auto">Thanks, will this be fixed in the future?</p>
]]></description><link>https://community.m5stack.com/post/23391</link><guid isPermaLink="true">https://community.m5stack.com/post/23391</guid><dc:creator><![CDATA[codeblue]]></dc:creator><pubDate>Fri, 19 Jan 2024 06:09:33 GMT</pubDate></item><item><title><![CDATA[Reply to Kernel crashed when rotate the M5dial encoder fast on Fri, 19 Jan 2024 04:03:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/codeblue" aria-label="Profile: codeblue">@<bdi>codeblue</bdi></a> The BtnA.setCallback method causes this exception.<br />
A temporary workaround:<br />
<img src="/assets/uploads/files/1705636937980-72c94abe-d2fa-473c-845d-f323608400c5-image-resized.png" alt="0_1705636943825_72c94abe-d2fa-473c-845d-f323608400c5-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/23388</link><guid isPermaLink="true">https://community.m5stack.com/post/23388</guid><dc:creator><![CDATA[lbuque]]></dc:creator><pubDate>Fri, 19 Jan 2024 04:03:06 GMT</pubDate></item><item><title><![CDATA[Reply to Kernel crashed when rotate the M5dial encoder fast on Fri, 19 Jan 2024 02:02:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> 我如果不用类的写法， 而直接写方法，程序跑起来就没问题， 也不需要 gc.collect()</p>
<p dir="auto">应该不是内存的问题， 因为崩溃的时候，或者报 TypeError: '' object isn't callable 的时候  hold0 还没输出， 说明还没进入btnA_wasHold_event函数， 有可能是btnA 设置回调的时候， 不能设置 self.xxxx 这样的对象函数？</p>
]]></description><link>https://community.m5stack.com/post/23387</link><guid isPermaLink="true">https://community.m5stack.com/post/23387</guid><dc:creator><![CDATA[codeblue]]></dc:creator><pubDate>Fri, 19 Jan 2024 02:02:45 GMT</pubDate></item><item><title><![CDATA[Reply to Kernel crashed when rotate the M5dial encoder fast on Thu, 18 Jan 2024 12:10:57 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/codeblue" aria-label="Profile: codeblue">@<bdi>codeblue</bdi></a></p>
<p dir="auto">it seems that adding a <code>gc.collect()</code> call after line <code>self.ble.gap_advertise(None)</code> prevents the crash/error.</p>
]]></description><link>https://community.m5stack.com/post/23381</link><guid isPermaLink="true">https://community.m5stack.com/post/23381</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 18 Jan 2024 12:10:57 GMT</pubDate></item><item><title><![CDATA[Reply to Kernel crashed when rotate the M5dial encoder fast on Thu, 18 Jan 2024 01:18:22 GMT]]></title><description><![CDATA[<p dir="auto">Hi Felix, can you help? <a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a></p>
]]></description><link>https://community.m5stack.com/post/23378</link><guid isPermaLink="true">https://community.m5stack.com/post/23378</guid><dc:creator><![CDATA[codeblue]]></dc:creator><pubDate>Thu, 18 Jan 2024 01:18:22 GMT</pubDate></item></channel></rss>
