<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Trouble flashing AWS-S3-PUT example to TimerCam-F with ESP-IDF + PlatformIO]]></title><description><![CDATA[<p dir="auto">The project compiles fine, but fails to flash, failing with the following.  Has anyone encountered and resolved this?</p>
<pre><code>Building in release mode
Retrieving maximum program size .pio/build/m5stack-timer-cam/firmware.elf
Checking size .pio/build/m5stack-timer-cam/firmware.elf
Advanced Memory Usage is available via "PlatformIO Home &gt; Project Inspect"
RAM:   [=         ]  11.6% (used 38052 bytes from 327680 bytes)
Flash: [==========]  96.0% (used 1006333 bytes from 1048576 bytes)
Configuring upload protocol...
AVAILABLE: cmsis-dap, esp-bridge, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
CURRENT: upload_protocol = esptool
Looking for upload port...
Auto-detected: /dev/cu.usbserial-59527C0548
Uploading .pio/build/m5stack-timer-cam/firmware.bin
esptool.py v4.5.1
Serial port /dev/cu.usbserial-59527C0548
Connecting....
Chip is ESP32-D0WDQ6-V3 (revision v3.1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: b0:b2:1c:60:bf:b0
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
A fatal error occurred: Unable to verify flash chip connection (No serial data received.).
*** [upload] Error 2
]]></description><link>https://community.m5stack.com/topic/5995/trouble-flashing-aws-s3-put-example-to-timercam-f-with-esp-idf-platformio</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 21:18:58 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5995.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 18 Jan 2024 22:09:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Trouble flashing AWS-S3-PUT example to TimerCam-F with ESP-IDF + PlatformIO on Thu, 10 Oct 2024 13:03:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/inteladata" aria-label="Profile: inteladata">@<bdi>inteladata</bdi></a> Try setting baud rate to 1500000.</p>
]]></description><link>https://community.m5stack.com/post/26681</link><guid isPermaLink="true">https://community.m5stack.com/post/26681</guid><dc:creator><![CDATA[M5User-60283]]></dc:creator><pubDate>Thu, 10 Oct 2024 13:03:43 GMT</pubDate></item></channel></rss>
