<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I&#x27;ve found a method to program Core S3 using Python.]]></title><description><![CDATA[<p dir="auto">I've found a method to program Core S3 using Python.<br />
I'm interested in getting feedback if anyone has a better method.</p>
<li>Install UIFlow2.0 using m5Burner</li>
<li>Go to <a href="http://uiflow2.m5stack.com" target="_blank" rel="noopener noreferrer nofollow ugc">uiflow2.m5stack.com</a></li>
<li>Click on the python tab, &lt;/&gt;</li>
<li>Click on Read Mode</li>
<li>Edit your Python code</li>
<li>Click on "Download the program to device"</li>
<li>It will start automatically.</li>
<li>Repeat from 5 until you programming is done.</li>
<p dir="auto">If you click on "Read Mode"/"Custom Edit", you will lose your code changes.<br />
I have NOT found a method of transfering files instead, so I am using Copy &amp; Paste at the moment.</p>
<p dir="auto">I did NOT find any debugger so I'm using print() instead.</p>
<p dir="auto">Not much documentation online, but UIFlow creates Python code, which you can simplify and reuse.</p>
<p dir="auto">You need to check these links: <a href="https://docs.micropython.org" target="_blank" rel="noopener noreferrer nofollow ugc">MicroPython</a> and <a href="https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/docs/products/core/CoreS3/CoreS3%20Development%20Kit-compressed%20(1).pdf" target="_blank" rel="noopener noreferrer nofollow ugc">Core S3</a></p>
]]></description><link>https://community.m5stack.com/topic/6021/i-ve-found-a-method-to-program-core-s3-using-python</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 20:15:23 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6021.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 26 Jan 2024 17:34:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to I&#x27;ve found a method to program Core S3 using Python. on Fri, 26 Jan 2024 21:58:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/christer" aria-label="Profile: christer">@<bdi>christer</bdi></a></p>
<p dir="auto">I have been using the Arduino IDE to create and compile and transfer code to my CoreS3.<br />
Very simple.</p>
<p dir="auto">There are lots if GutHub examples written ro this IDE.</p>
]]></description><link>https://community.m5stack.com/post/23484</link><guid isPermaLink="true">https://community.m5stack.com/post/23484</guid><dc:creator><![CDATA[Cohen]]></dc:creator><pubDate>Fri, 26 Jan 2024 21:58:25 GMT</pubDate></item><item><title><![CDATA[Reply to I&#x27;ve found a method to program Core S3 using Python. on Fri, 26 Jan 2024 20:14:04 GMT]]></title><description><![CDATA[<p dir="auto">Micropython has been accessible since the early versions as UIFlow is built on Micropython.<br />
The very best way is to use Thonny which allows you to add libraries and edit code without UIFlows IDE</p>
<p dir="auto">By the way, Thanks for linking to my guide and another is on its way but you can check out my GITHUB for updates.<br />
<a href="https://github.com/Ajb2k3/UIFlowHandbook" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Ajb2k3/UIFlowHandbook</a></p>
]]></description><link>https://community.m5stack.com/post/23481</link><guid isPermaLink="true">https://community.m5stack.com/post/23481</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 26 Jan 2024 20:14:04 GMT</pubDate></item></channel></rss>
