<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[AtomS3: No serial data received.]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">My AtomS3 appears unresponsive after attempting to upload my first project. Now, every attempt to connect results in "A fatal error occurred: Failed to connect to Espressif device: No serial data received." The device shows a blank screen and doesn't respond.</p>
<p dir="auto">Is there a way to perform a hardware-based factory reset using the buttons on the device?</p>
<p dir="auto">Thank you for your help.</p>
]]></description><link>https://community.m5stack.com/topic/6033/atoms3-no-serial-data-received</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 04:15:24 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6033.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 28 Jan 2024 00:18:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to AtomS3: No serial data received. on Sun, 28 Jan 2024 17:37:40 GMT]]></title><description><![CDATA[<p dir="auto">Felmue, you genius you,</p>
<p dir="auto">THANK YOU! Newbie high-five.</p>
]]></description><link>https://community.m5stack.com/post/23526</link><guid isPermaLink="true">https://community.m5stack.com/post/23526</guid><dc:creator><![CDATA[M_Bison]]></dc:creator><pubDate>Sun, 28 Jan 2024 17:37:40 GMT</pubDate></item><item><title><![CDATA[Reply to AtomS3: No serial data received. on Sun, 28 Jan 2024 12:50:18 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/m_bison" aria-label="Profile: M_Bison">@<bdi>M_Bison</bdi></a></p>
<p dir="auto">check the yellow section in Description from the M5AtomS3 <a href="https://docs.m5stack.com/en/core/AtomS3" target="_blank" rel="noopener noreferrer nofollow ugc">documentation</a>.</p>
<p dir="auto"><em>Reminder: If you need to burn the firmware, please press and hold the reset button (about 2 seconds) until the internal green LED lights up, then you can release it, at this time the device has entered download mode and waited for burning.</em></p>
]]></description><link>https://community.m5stack.com/post/23511</link><guid isPermaLink="true">https://community.m5stack.com/post/23511</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 28 Jan 2024 12:50:18 GMT</pubDate></item></channel></rss>
