<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core 2 after a failed update: clic clic clic but no visible com port on the pc]]></title><description><![CDATA[<p dir="auto">Hello, Again the problem everybody seems to have. So I try to summarise my situation:</p>
<li>It crasehd in an update, dont ask me why.</li>
<li>After this, I can not reset the core2. I pushed the 2 buttons in every possible time and combination.</li>
<li>The windows does not see the USB/COM 6 anymore.</li>
<li>The Core2 is not dead because it does clic clic clic in the speaker.</li>
<li>I tried to unplug the battery and plug again, nothing.<br />
=&gt; Do I just have to bin it and order the next one? or is there a way to get this great device back to a normal life? :-)</li>
]]></description><link>https://community.m5stack.com/topic/6073/core-2-after-a-failed-update-clic-clic-clic-but-no-visible-com-port-on-the-pc</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 23:23:15 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6073.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 09 Feb 2024 21:18:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Core 2 after a failed update: clic clic clic but no visible com port on the pc on Fri, 09 Feb 2024 21:45:59 GMT]]></title><description><![CDATA[<p dir="auto">Sorry, but I will close the topic by giving the answer myself :-).<br />
I was realy lost but tried the following (based on some other reading)</p>
<li>I changed the cable and took the short usb cable that I found in the box.</li>
<li>I plugged, made myself ready with the erase process</li>
<li>I pressed the on, pressed the reset and released, release the on</li>
<li>The com6 was again an option on the m5 burner.</li>
<li>I started by erasing, the clic clic was still present.</li>
<li>I burned a new firmware, the machine is working again.<br />
I hope it will help similar cases :-)</li>
]]></description><link>https://community.m5stack.com/post/23734</link><guid isPermaLink="true">https://community.m5stack.com/post/23734</guid><dc:creator><![CDATA[ChristopheH]]></dc:creator><pubDate>Fri, 09 Feb 2024 21:45:59 GMT</pubDate></item></channel></rss>
