<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5 stick cplus 1.1 won&#x27;t connect]]></title><description><![CDATA[<p dir="auto">I am trying to to get my new m5 stick to connect to my pc so I can send code from UI flow IDE. I've installed every driver from github and the ftdi chip site. When plugged in it shows up in device manager as com3. When I open uiflow it let's me select the device and com 3 (the only one available) but when I try to download anything to it, it says disconnected. Please help!</p>
]]></description><link>https://community.m5stack.com/topic/6084/m5-stick-cplus-1-1-won-t-connect</link><generator>RSS for Node</generator><lastBuildDate>Wed, 06 May 2026 01:28:33 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6084.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 13 Feb 2024 02:41:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5 stick cplus 1.1 won&#x27;t connect on Tue, 13 Feb 2024 17:13:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bdtprez" aria-label="Profile: bdtprez">@<bdi>bdtprez</bdi></a> You need to burn UIFlow2 for the StickCplus NOT StickCplus2!</p>
<p dir="auto">If you burn any other firmware you will not get access to UIFlow.</p>
<p dir="auto">Keep trying changing the baud rate, I don't have win10 so I cant test  and help any more.</p>
]]></description><link>https://community.m5stack.com/post/23790</link><guid isPermaLink="true">https://community.m5stack.com/post/23790</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 13 Feb 2024 17:13:41 GMT</pubDate></item><item><title><![CDATA[Reply to M5 stick cplus 1.1 won&#x27;t connect on Tue, 13 Feb 2024 15:33:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bdtprez" aria-label="Profile: bdtprez">@<bdi>bdtprez</bdi></a> general rule is to keep controller firmware same as web uiflow version, so current web uiflow 2.0 is 2.0.1 and such firmware is available via M5Burner, Uiflow 2.0 has build in firmware manager too.  (botom left hand side).</p>
]]></description><link>https://community.m5stack.com/post/23789</link><guid isPermaLink="true">https://community.m5stack.com/post/23789</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Tue, 13 Feb 2024 15:33:42 GMT</pubDate></item><item><title><![CDATA[Reply to M5 stick cplus 1.1 won&#x27;t connect on Tue, 13 Feb 2024 15:11:15 GMT]]></title><description><![CDATA[<p dir="auto">Thank you so much! I was able to flash an unofficial firmware to the device with M5burner successfully! I had to lower the baud rate to 115200 for a successful flash. I'm still having issues connecting with UI flow but at least i have something to work with. Is there a way to lower the baud rate in UIFlow??</p>
]]></description><link>https://community.m5stack.com/post/23788</link><guid isPermaLink="true">https://community.m5stack.com/post/23788</guid><dc:creator><![CDATA[bdtprez]]></dc:creator><pubDate>Tue, 13 Feb 2024 15:11:15 GMT</pubDate></item><item><title><![CDATA[Reply to M5 stick cplus 1.1 won&#x27;t connect on Tue, 13 Feb 2024 14:50:52 GMT]]></title><description><![CDATA[<p dir="auto">Sorry that i left out so much information. M5 Stick C plus 1.1 on windows 10 64 bit. Im going to try M5 burner now, Thank you!</p>
]]></description><link>https://community.m5stack.com/post/23787</link><guid isPermaLink="true">https://community.m5stack.com/post/23787</guid><dc:creator><![CDATA[bdtprez]]></dc:creator><pubDate>Tue, 13 Feb 2024 14:50:52 GMT</pubDate></item><item><title><![CDATA[Reply to M5 stick cplus 1.1 won&#x27;t connect on Tue, 13 Feb 2024 11:23:36 GMT]]></title><description><![CDATA[<p dir="auto">When you press the erase button in M5Burner, hit the sticks reset button. Btw which stick?</p>
]]></description><link>https://community.m5stack.com/post/23784</link><guid isPermaLink="true">https://community.m5stack.com/post/23784</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 13 Feb 2024 11:23:36 GMT</pubDate></item><item><title><![CDATA[Reply to M5 stick cplus 1.1 won&#x27;t connect on Tue, 13 Feb 2024 08:57:52 GMT]]></title><description><![CDATA[<p dir="auto">download M5burner then install latest firmware in to your M5Stick+</p>
]]></description><link>https://community.m5stack.com/post/23779</link><guid isPermaLink="true">https://community.m5stack.com/post/23779</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Tue, 13 Feb 2024 08:57:52 GMT</pubDate></item></channel></rss>
