<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5 CoreS3 problems]]></title><description><![CDATA[<p dir="auto">I have just got the M5 CoreS3, I have played with the ESP32S3 a bit, but this is my first M5Stack unit.</p>
<p dir="auto">I am having lots of problems. If I take it as is, it will not talk to my Windows 11 computer (the only computer I have tried so far)</p>
<li>
<p dir="auto">why is there not a group for it on in the Community, that is why I am starting here?</p>
</li>
<li>
<p dir="auto">if I have it as shipped, I get a bad USB device and no comms port. I have two comms ports reported, but I think these are from another ESP32S3, but I can not find it currently. Far too many USB cables</p>
</li>
<li>
<p dir="auto">if I unplug the "DIN BASE" from the stack, Then sometimes (most of the time) I get a comms port trying to pull the firmware out, I like to back up things, but after a few minutes the unit reboot and it loss the comms port, and unplug it for a minute or so and then plug it back in the comms port comes back.</p>
</li>
<li>
<p dir="auto">my virus scanner does not like "CoreS3 TP Upgrade V0.5.exe"</p>
</li>
<p dir="auto">Roger</p>
]]></description><link>https://community.m5stack.com/topic/6094/m5-cores3-problems</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 07:05:12 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6094.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 15 Feb 2024 22:00:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5 CoreS3 problems on Fri, 16 Feb 2024 06:14:25 GMT]]></title><description><![CDATA[<p dir="auto">No, The ESP32S3 does indeed have 2 com ports but you have to put the Core S3 into Boot mode to program it.</p>
<p dir="auto"><a href="https://youtu.be/2K4hHGtskAU" target="_blank" rel="noopener noreferrer nofollow ugc">https://youtu.be/2K4hHGtskAU</a></p>
<ol start="2">
<li>In most cases it's the USB cable or the Host PC that is the problem. Windows has issues with its come port communications with S3's.</li>
<li>huh, what, All firmware is available in M5Burner unless you made it yourself then you should be backing up your own files.</li>
<li>Never heard of CoreS3 TP Upgrade V0.5.exe<br />
M5Burner is the program for burning firmware.</li>
]]></description><link>https://community.m5stack.com/post/23842</link><guid isPermaLink="true">https://community.m5stack.com/post/23842</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 16 Feb 2024 06:14:25 GMT</pubDate></item></channel></rss>
