<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Error at NTP module on UIFlow2 and Cardputer: Missing timezone]]></title><description><![CDATA[<p dir="auto">Set timezone: GMT-3 on Blockly throws error:<br />
AttributeError: 'module' object has no attribute 'timezone'</p>
<p dir="auto">Please advice.</p>
]]></description><link>https://community.m5stack.com/topic/6115/error-at-ntp-module-on-uiflow2-and-cardputer-missing-timezone</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 06:42:12 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6115.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 20 Feb 2024 20:27:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Error at NTP module on UIFlow2 and Cardputer: Missing timezone on Wed, 21 Feb 2024 12:29:35 GMT]]></title><description><![CDATA[<p dir="auto">I observe that there seems to be an NTP init step at the begin of the default UIFlow2 firmware startup, as the required arguments are part of the burn and configuration options. There is no more NTP section in the UIFLow2 blocks but a so called “Time” section thats delivers the “set timezone” command, which is in error. Please confirm the NTP was moved into the firmware and "Time" and also check why the “timezone” module was not loaded by the firmware. Thanks for support. Shouldn't there be a mandatory Wifi connection setup before issuing an NTP request?  Further, I got NTP data but with strange return values like: 2054,2,20,12,11.. . Why?</p>
]]></description><link>https://community.m5stack.com/post/23975</link><guid isPermaLink="true">https://community.m5stack.com/post/23975</guid><dc:creator><![CDATA[falbriard]]></dc:creator><pubDate>Wed, 21 Feb 2024 12:29:35 GMT</pubDate></item><item><title><![CDATA[Reply to Error at NTP module on UIFlow2 and Cardputer: Missing timezone on Wed, 21 Feb 2024 07:58:36 GMT]]></title><description><![CDATA[<p dir="auto">is NTP unit/module available in uiflow 2.0 blocks?  can only see RTC  in Hardware</p>
]]></description><link>https://community.m5stack.com/post/23965</link><guid isPermaLink="true">https://community.m5stack.com/post/23965</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Wed, 21 Feb 2024 07:58:36 GMT</pubDate></item></channel></rss>
