<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[SD card on M5 capsule - how to make it work ?]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I recently bought a M5 capsule, it's a super nice device. At one moment, i want to dump some files to the sd card. Unfortunately, no "sd" folder is recognized. I tried a micro sd card of 32Gb, 64Gb and 4GB. all are formatted in FAT32. But i don't see anything.</p>
<p dir="auto">Anyone having a similar issue ?</p>
<p dir="auto">Hope to solve this quick :)</p>
<p dir="auto">L31BN1TZ</p>
]]></description><link>https://community.m5stack.com/topic/6130/sd-card-on-m5-capsule-how-to-make-it-work</link><generator>RSS for Node</generator><lastBuildDate>Thu, 07 May 2026 15:05:18 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6130.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 21 Feb 2024 16:25:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to SD card on M5 capsule - how to make it work ? on Fri, 23 Feb 2024 15:34:39 GMT]]></title><description><![CDATA[<p dir="auto">specific pins are available here : <a href="https://github.com/m5stack/M5Unified" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5Unified</a></p>
]]></description><link>https://community.m5stack.com/post/24070</link><guid isPermaLink="true">https://community.m5stack.com/post/24070</guid><dc:creator><![CDATA[l31bn1tz]]></dc:creator><pubDate>Fri, 23 Feb 2024 15:34:39 GMT</pubDate></item><item><title><![CDATA[Reply to SD card on M5 capsule - how to make it work ? on Fri, 23 Feb 2024 15:33:46 GMT]]></title><description><![CDATA[<p dir="auto">I solved the problem, for those having the same problem, i fix it by init the sd card :</p>
<p dir="auto">import os, sys, io<br />
import M5<br />
from M5 import *<br />
from hardware import *<br />
from hardware import sdcard</p>
<p dir="auto">def setup():<br />
M5.begin()<br />
sdcard.SDCard(slot=3, width=1, sck=14, miso=39, mosi=12, cs=11, freq=1000000)<br />
print(os.listdir('/sd/'))</p>
]]></description><link>https://community.m5stack.com/post/24069</link><guid isPermaLink="true">https://community.m5stack.com/post/24069</guid><dc:creator><![CDATA[l31bn1tz]]></dc:creator><pubDate>Fri, 23 Feb 2024 15:33:46 GMT</pubDate></item><item><title><![CDATA[Reply to SD card on M5 capsule - how to make it work ? on Thu, 22 Feb 2024 13:19:48 GMT]]></title><description><![CDATA[<p dir="auto">while connecting through thonny, i can only see flash and system at the root of the device.</p>
<p dir="auto">What do you mean by import and mount ?</p>
]]></description><link>https://community.m5stack.com/post/24029</link><guid isPermaLink="true">https://community.m5stack.com/post/24029</guid><dc:creator><![CDATA[l31bn1tz]]></dc:creator><pubDate>Thu, 22 Feb 2024 13:19:48 GMT</pubDate></item><item><title><![CDATA[Reply to SD card on M5 capsule - how to make it work ? on Thu, 22 Feb 2024 10:14:03 GMT]]></title><description><![CDATA[<p dir="auto">Have you imported and mounted the card?</p>
]]></description><link>https://community.m5stack.com/post/24024</link><guid isPermaLink="true">https://community.m5stack.com/post/24024</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 22 Feb 2024 10:14:03 GMT</pubDate></item></channel></rss>
