<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Programming Atom Matrix with external FTDI?]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I have an Atom Matrix which I cannot connect to. No serial connection or serial timeouts. It seems to work regularly since it powers on and cycles through the matrix colors as expected when pushing the button.</p>
<p dir="auto">Unless I am missing a secret trick to program it, or there is a way to "hard reset" it, I am suspecting the USB connection / USB UART is faulty.</p>
<p dir="auto">Would it be possible to use an external FTDI Adapter to connect to the externally accessible pins and program it this way?</p>
<p dir="auto">Any hints appreciated.</p>
<p dir="auto">Thank you!</p>
]]></description><link>https://community.m5stack.com/topic/6140/programming-atom-matrix-with-external-ftdi</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 07:05:08 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6140.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 23 Feb 2024 11:53:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Programming Atom Matrix with external FTDI? on Fri, 23 Feb 2024 13:10:54 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/stackerbob" aria-label="Profile: StackerBob">@<bdi>StackerBob</bdi></a></p>
<p dir="auto">unfortunately no, to manually put ESP32 into download mode GPIO1, GPIO3 and GPIO0 are required, none of them are externally accessible. Also see schematic <a href="https://docs.m5stack.com/en/core/ATOM%20Matrix" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
]]></description><link>https://community.m5stack.com/post/24067</link><guid isPermaLink="true">https://community.m5stack.com/post/24067</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 23 Feb 2024 13:10:54 GMT</pubDate></item></channel></rss>
