<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Best way to power Core2 without battery]]></title><description><![CDATA[<p dir="auto">I want to use the Core2 module in a product and power it from 5V but not use the internal battery.  I want the Core2 to be powered on and off when the main unit is powered on and off.  Currently, I am powering the Core2 from the 30-pin connector (pin28=5V and pin 1,3,5=GND)and that seemed to work until recently when it will not power on anymore.  The green LED flashes once but the Core2 does not power on.  If I install the battery, the Core2 powers up fine.</p>
<p dir="auto">What's the best way to power up the Core2 from external power, not using the p-pin external connectors?</p>
<p dir="auto">Thank you.</p>
]]></description><link>https://community.m5stack.com/topic/6169/best-way-to-power-core2-without-battery</link><generator>RSS for Node</generator><lastBuildDate>Fri, 08 May 2026 06:46:19 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6169.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 29 Feb 2024 22:03:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Best way to power Core2 without battery on Fri, 01 Mar 2024 14:11:21 GMT]]></title><description><![CDATA[<p dir="auto">Supply power via the MBus on the under side of the core2</p>
]]></description><link>https://community.m5stack.com/post/24215</link><guid isPermaLink="true">https://community.m5stack.com/post/24215</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 01 Mar 2024 14:11:21 GMT</pubDate></item><item><title><![CDATA[Reply to Best way to power Core2 without battery on Fri, 01 Mar 2024 13:38:33 GMT]]></title><description><![CDATA[<p dir="auto">Made no changes...</p>
]]></description><link>https://community.m5stack.com/post/24214</link><guid isPermaLink="true">https://community.m5stack.com/post/24214</guid><dc:creator><![CDATA[pribusin]]></dc:creator><pubDate>Fri, 01 Mar 2024 13:38:33 GMT</pubDate></item><item><title><![CDATA[Reply to Best way to power Core2 without battery on Fri, 01 Mar 2024 07:34:35 GMT]]></title><description><![CDATA[<p dir="auto">what happened in meantime did you updated Core2 firmware or is it same as was?</p>
]]></description><link>https://community.m5stack.com/post/24210</link><guid isPermaLink="true">https://community.m5stack.com/post/24210</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Fri, 01 Mar 2024 07:34:35 GMT</pubDate></item></channel></rss>
