<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New M5Stack Core 2 device captive buttons]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">As per the title does anyone else have the latest device have you had any success in using your device?</p>
<p dir="auto">I tried to flash with UIFlow 2 seems reboot fine with the UIFlow UI but when you try to use the desktop (Windows 10) version of UIFlow app it can't connect.</p>
<p dir="auto">M5 Burner works fine picks up the device.</p>
<p dir="auto">Arudino IDE also worked initially but that caused issues had to erase the device (eventually) and the flash the UIFlow base rom then flash to version 2.x.</p>
<p dir="auto">Do the captive buttons work at all there is no idea if they do I was told to hold down the middle button to display a dev menu but that doesn't work.</p>
<p dir="auto">Thank in advance and apologies for the dumb questions new to all this.</p>
<p dir="auto">Trev</p>
]]></description><link>https://community.m5stack.com/topic/6170/new-m5stack-core-2-device-captive-buttons</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 06:48:42 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6170.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 01 Mar 2024 15:12:04 GMT</pubDate><ttl>60</ttl></channel></rss>
