<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Is Relay Unit programming broken]]></title><description><![CDATA[<p dir="auto">Stupid question! I have been trying to get my relay units working on UIFLow 2 with an AtomS3Lite and on UIFLow 1 with a Stamp Pico. I've resorted to very basic programming to turn the relay unit on and off once every 5 seconds and they are not working. I have used these M5stack relay units only last week and they were both working fine.<br />
I'm just wondering if something is broken in both versions of UIFLow??</p>
]]></description><link>https://community.m5stack.com/topic/6191/is-relay-unit-programming-broken</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 04:00:22 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6191.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 09 Mar 2024 01:28:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Is Relay Unit programming broken on Sat, 09 Mar 2024 11:57:03 GMT]]></title><description><![CDATA[<p dir="auto">Thanks ajb2k3,<br />
I did manage to get my Stamp Pico working with both a PIR sensor and relay unit.<br />
The problem was my fault. In soldering on the grove connector to the Stamp Pico, I soldered it on the wrong side of the board so when I connected a grove cable - ground was connected to GPIO 33, 5v was connected to GPIO 32, GPIO 32 was connected to 5v and GPIO 33 was connected to ground. Fortunately I didn't cook my board.</p>
]]></description><link>https://community.m5stack.com/post/24312</link><guid isPermaLink="true">https://community.m5stack.com/post/24312</guid><dc:creator><![CDATA[Kombistack]]></dc:creator><pubDate>Sat, 09 Mar 2024 11:57:03 GMT</pubDate></item><item><title><![CDATA[Reply to Is Relay Unit programming broken on Sat, 09 Mar 2024 06:41:49 GMT]]></title><description><![CDATA[<p dir="auto">By default the port is set as a digital/I2CPort and so normally a relay unit wouldn't work.</p>
<p dir="auto">Oh BTW the default Port is A not B, the terminal says you set it to port B which doesn't exist on the Atom and stamp.</p>
]]></description><link>https://community.m5stack.com/post/24308</link><guid isPermaLink="true">https://community.m5stack.com/post/24308</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 09 Mar 2024 06:41:49 GMT</pubDate></item><item><title><![CDATA[Reply to Is Relay Unit programming broken on Sat, 09 Mar 2024 04:57:56 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1709960191656-uiflow.jpg" alt="0_1709960204161_uiflow.jpg" class=" img-fluid img-markdown" /><br />
This is the simple program</p>
<p dir="auto"><img src="/assets/uploads/files/1709960217901-terminal.jpg" alt="0_1709960227582_terminal.jpg" class=" img-fluid img-markdown" /><br />
This is the terminal response.<br />
Does this indicate a problem with the Relay Unit programming in UIFlow?</p>
]]></description><link>https://community.m5stack.com/post/24307</link><guid isPermaLink="true">https://community.m5stack.com/post/24307</guid><dc:creator><![CDATA[Kombistack]]></dc:creator><pubDate>Sat, 09 Mar 2024 04:57:56 GMT</pubDate></item></channel></rss>
