<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Product Revision] Tube&#x2F;Air Pressure Unit with I2C]]></title><description><![CDATA[<p dir="auto">Tube/Air Pressure Unit (U130) with I2C output instead of analog (I2C Sensor or I2C ADC)</p>
]]></description><link>https://community.m5stack.com/topic/6215/product-revision-tube-air-pressure-unit-with-i2c</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 22:01:41 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6215.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 15 Mar 2024 00:51:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Product Revision] Tube&#x2F;Air Pressure Unit with I2C on Wed, 23 Jul 2025 06:18:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maethaxi" aria-label="Profile: Maethaxi">@<bdi>Maethaxi</bdi></a> Thanks I was looking for a Tube/Air Pressure unit with a <strong>I2C</strong> interface...  I was trying to use the M5Stack Tube/Air Pressure Unit but I am running into an issue so I figured I would look for other options if I can't get it to work accurately...  I need a sensor sensitive enough to detect someone blowing lightly in a tube....</p>
]]></description><link>https://community.m5stack.com/post/29585</link><guid isPermaLink="true">https://community.m5stack.com/post/29585</guid><dc:creator><![CDATA[Kenzo]]></dc:creator><pubDate>Wed, 23 Jul 2025 06:18:53 GMT</pubDate></item><item><title><![CDATA[Reply to [Product Revision] Tube&#x2F;Air Pressure Unit with I2C on Tue, 21 Jan 2025 21:57:43 GMT]]></title><description><![CDATA[<p dir="auto">There's a similar request here:<br />
<a href="https://community.m5stack.com/topic/5241/new-module-sdp3x-differential-pressure-sensor">https://community.m5stack.com/topic/5241/new-module-sdp3x-differential-pressure-sensor</a></p>
]]></description><link>https://community.m5stack.com/post/27980</link><guid isPermaLink="true">https://community.m5stack.com/post/27980</guid><dc:creator><![CDATA[Maecksu]]></dc:creator><pubDate>Tue, 21 Jan 2025 21:57:43 GMT</pubDate></item><item><title><![CDATA[Reply to [Product Revision] Tube&#x2F;Air Pressure Unit with I2C on Mon, 03 Jun 2024 16:28:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maethaxi" aria-label="Profile: Maethaxi">@<bdi>Maethaxi</bdi></a> Adafruit has them as well: <a href="https://www.adafruit.com/product/4424" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.adafruit.com/product/4424</a></p>
]]></description><link>https://community.m5stack.com/post/25472</link><guid isPermaLink="true">https://community.m5stack.com/post/25472</guid><dc:creator><![CDATA[Zavyru]]></dc:creator><pubDate>Mon, 03 Jun 2024 16:28:15 GMT</pubDate></item><item><title><![CDATA[Reply to [Product Revision] Tube&#x2F;Air Pressure Unit with I2C on Wed, 24 Apr 2024 19:11:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/teastain" aria-label="Profile: teastain">@<bdi>teastain</bdi></a><br />
Thanks for pointing out what the connectors are for M5Stack &amp; SparkFun. I usually use "Grove2Dupont Conversion Cable 20cm (5Pairs)" (SKU: A096) for adapting stuff to grove. I'll add some JST PH (2.0) &amp; JST SH (1.0) to my next components order.<br />
You're right, definitely opens up a whole new world of accessories!</p>
]]></description><link>https://community.m5stack.com/post/24930</link><guid isPermaLink="true">https://community.m5stack.com/post/24930</guid><dc:creator><![CDATA[Maethaxi]]></dc:creator><pubDate>Wed, 24 Apr 2024 19:11:04 GMT</pubDate></item><item><title><![CDATA[Reply to [Product Revision] Tube&#x2F;Air Pressure Unit with I2C on Wed, 24 Apr 2024 20:24:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maethaxi" aria-label="Profile: maethaxi">@<bdi>maethaxi</bdi></a> Good info!</p>
<p dir="auto">The Adafruit must be an older design, as the I2C pins are not in the Grove signal order and would require cutting the end from a Grove cable and crossing wires and soldering!</p>
<p dir="auto">The Sparkfun unit is 'micro-grove' JST 1.0mm but wired correctly for grove. You would need a JST 2.0 (Grove) to JST 1.0 (qwiic) adapter cable. Mine is homemade but opens up another world of sensors to my faithful M5Stack equipment!<br />
added:<br />
Sparkfun qwiic to Grove converter cable<br />
<a href="https://www.sparkfun.com/products/15109" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.sparkfun.com/products/15109</a></p>
]]></description><link>https://community.m5stack.com/post/24929</link><guid isPermaLink="true">https://community.m5stack.com/post/24929</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Wed, 24 Apr 2024 20:24:54 GMT</pubDate></item><item><title><![CDATA[Reply to [Product Revision] Tube&#x2F;Air Pressure Unit with I2C on Wed, 24 Apr 2024 15:02:22 GMT]]></title><description><![CDATA[<p dir="auto">Adafruit makes one: <a href="https://www.adafruit.com/product/3965" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.adafruit.com/product/3965</a><br />
SparkFun also makes one: <a href="https://www.sparkfun.com/products/16476" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.sparkfun.com/products/16476</a></p>
]]></description><link>https://community.m5stack.com/post/24926</link><guid isPermaLink="true">https://community.m5stack.com/post/24926</guid><dc:creator><![CDATA[Maethaxi]]></dc:creator><pubDate>Wed, 24 Apr 2024 15:02:22 GMT</pubDate></item></channel></rss>
